Old 02-05-2008, 12:21 AM   #1 (permalink)
crl
crl's Avatar
Default SRS Light
If the "SRS" light is illuminated is there anything I can do about it or is the only way to go to a mechanic?
In the last eight uses of the truck it has been on six times.
I have checked the fuse and all seems to be ok there.
crl is offline   Reply With Quote
Old 02-05-2008, 04:43 AM   #2 (permalink)
Mechanic only. Either you have a low voltage issue, a seat belt problem or maybe a spiral ring failing.
Old 02-07-2008, 02:32 PM   #3 (permalink)
ruidisco's Avatar
Hi!
My 01 DII, had the same problem. It hapenned after a higway trip here in Portugal, i´ve packed some stuff under the front seats. The result as been a SRS light on how? It simply as disconnected the yellow connector from SRS/Airbag harness. The mecanic adviced me to check this connections before any action or test. And he was wright, the problem was just a bad contact in the connector, i've unplugged and plugged it again, and problem solved! You should check yours too.
Best Regards
ruidisco is offline   Reply With Quote
91 and Oil Light tonyurban Range Rover Classic 3 02-01-2008 07:46 AM
brake light bulb mystery chrisusvi Discovery Series I 3 02-13-2007 09:19 AM
1999 Discovery Light bulb guide darkknight1999 Accessories 3 03-22-2006 09:31 AM
How do I reset the ABS light jsaturnia Discovery Series II 2 01-19-2006 12:09 PM
ot an old one but true ot 75series3 The Lounge 1 11-15-2005 08:08 AM
