Old 04-23-2008, 07:43 PM   #1 (permalink)
Toowild78's Avatar
Question SRS Light
I need a little help today while leaving work got in the disco truned on the key and there was nothing, so I got under the truck and tapped on the starter twice and it started??? No more starter problems thus far. New starter needed?? Also this evening the SRS light has came on 3 times and goes back off WTF is that about? Thanks for any help offered!
Toowild78 is offline   Reply With Quote
Old 04-23-2008, 08:08 PM   #2 (permalink)
If you would gp clean and tighten your battery cables, then go have your battery tested, you would find you probably have a bad battery that would explain the start issues and the SRS light, which is most likely a low voltage fault code for your air bags.
Old 04-24-2008, 02:39 AM   #3 (permalink)
ruidisco's Avatar
About the SRS light, my 01 Disco, has this problem. I've found out that is a bad contact on the yellow SRS connectors under the front seats. If you unplug a plug it again it should be ok.
Rui
01 DII
Go Anywhere!
ruidisco is offline   Reply With Quote
Old 04-24-2008, 06:05 AM   #4 (permalink)
Toowild78's Avatar
The battery is less then a month old and the terminals are nice and clean. The valve pan covers are seaping some could the be a contributing factor?
Old 04-24-2008, 07:10 AM   #5 (permalink)
If your v/c is leaking back onto the crank sensor, yes that can be the problem.
How long has the DRD light been on? If the system hasn't taken some low voltage then better go get the code read by your mechanic to find out for sure.
Old 04-24-2008, 10:25 AM   #6 (permalink)
Toowild78's Avatar
it just started coming on lastnight. As for the leaking I took disco to the local LR dealer and had the service department take a look I since I have dealt with them for several years I trust there judgement. They said the v/c leak was not an issues unless it would start burning on the EM and smelling.
Old 04-24-2008, 10:41 AM   #7 (permalink)
Toowild78's Avatar
Does the IM have to be removed to replace the v/c gaskets?
Check engine light and CA smog redbull_addict Range Rover Classic 7 11-26-2008 04:26 PM
brake light bulb mystery chrisusvi Discovery Series I 3 02-13-2007 10:19 AM
1999 Discovery Light bulb guide darkknight1999 Accessories 3 03-22-2006 10:31 AM
How do I reset the ABS light jsaturnia Discovery Series II 2 01-19-2006 01:09 PM
ot an old one but true ot 75series3 The Lounge 1 11-15-2005 09:08 AM
