Old 06-30-2008, 07:55 AM   #1 (permalink)
Default staring issue...
Hi All,
Once again, I have searched the forum and cannot find my situation... Here it goes...
I decided to go camping this weekend and all was 100% well until yesterday morning... I went to start the Disco. so we could come home and it cranked, tried to start, and then went dead. I tried it again and bam, it started, but the idle was higher than normal (about 1400 rpm)... I didn't think much of it... I hooked up my 26', 5300lb trailer and came home...
So this morning at home, the same thing... No indicator lights have come on and it seems fine otherwise... I'm lost...
In my search, I did find some suggestions about the Crank Position Sensor... Should I just replace this part and what is it and where is it located on the engine... I'm going to Seafoam her tonight and clean the intake and such, but I wanted to get a head start on the information so I can make some purchases ASAP!
Thanks in advance!
BTW, the Disco. is an awesome towing vehicle, with the help of some sway control and stay under 70mph... Even uphill!!!!
Jonathan
'03 Disco. HSE7 w/ACE and SLS and 54500 miles....
'03 Discovery HSE7 w/ACE and SLS...
jmrivera is offline   Reply With Quote
Old 06-30-2008, 08:38 AM   #2 (permalink)
Do you have a check engine light on?
Crank sensors don't always throw a code when they fail.
Is your drivers side v/c gasket leaking oil?
Don't worry about an induction clean or throttle body cleaning, good thing to do but won't help in this instance.
Old 06-30-2008, 08:47 AM   #3 (permalink)
No leaks anywhere (knock on wood) and no check engine light, or any others... That's why I say I'm lost...
One thing that is different is the fuel level is below what I normally let it get to. I never let it get below 3/4 tank and it was at half when this started... I remember reading somehwere that fuel level can have some effects in these vehicles...
Old 06-30-2008, 09:41 AM   #4 (permalink)
For as many crank sensors that fail every month between a number of the Rover fourms, I would lay my money on it.
Old 06-30-2008, 04:24 PM   #5 (permalink)
New Yawker in California
RudemanRB's Avatar
Gallery: 1
Being the victim of a Crank sensor failing, I'd put Mikes and My money on it.
Rudy
RudemanRB is offline   Reply With Quote
Old 06-30-2008, 08:22 PM   #6 (permalink)
Rudy
Do either of you have a sensor supplier??? I was going to go with either okierover or roverconnection...
Old 07-01-2008, 04:04 AM   #7 (permalink)
Another question...
I was poking around the engine looking for the sensor location, but was not certain I found it... Anyone care to point me in the right direction?
Old 07-01-2008, 05:26 AM   #8 (permalink)
Back side of the engine below the cylinder head, so it is squeazed between the engine and the fire wall.
Old 07-01-2008, 06:47 AM   #9 (permalink)
Well that sounds like it's going to be a fun project... How many times do you estimate I'll curse?
1996 discovery immobilizer issue - need help superderek3 Discovery Series I 1 06-14-2008 07:55 AM
Time is running out for Moab travel management comments jimfoo The Lounge 2 11-13-2007 01:27 PM
Another window issue Disco Truck Discovery Series I 5 03-16-2007 06:41 PM
Discovery I Issue hoberock Discovery Series I 15 02-06-2007 04:48 AM
Got My Issue of Land Rover Lifestyle Magazine WCURoverD90 General Land Rover Discussion 23 01-20-2006 06:14 PM
