Old 04-07-2008, 07:20 PM   #1 (permalink)
Default start up grinding noise
When I start my 99 DII when its cold out it makes a constant grinding noise for about 10 seconds then stops. It doesnt do it when its warm. I have no idea what it is. It doesnt sound like the engine though, it sounds more like its coming from under the car like the tranny. Any ideas?
ROVDOG
rovdog is offline   Reply With Quote
Old 04-08-2008, 05:32 AM   #2 (permalink)
Your Bendix assembly is stuck, when cold, causing the starter gear to stay engaged into the flex plate. You need to get rid of that starter before you damage the teeth on the flex plate, then you would have to separate the tranny from the engine to replace it also.
Whistling noise while accelerating (rather loud) jarnism Discovery Series II 3 02-24-2008 07:59 AM
Whistling noise while accelerating (rather loud) jarnism New Member Introductions 1 02-13-2008 09:15 AM
Cold Start... johnnybob06 Discovery Series II 10 03-20-2007 10:50 AM
Automatic Grinding? disco96 Discovery Series I 0 05-08-2005 09:26 AM
1995 Range Rover 4.0 Won't Start troverman Range Rover Classic 10 01-18-2005 05:33 AM
