Starting issues - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 01-02-2013, 05:13 AM   #1 (permalink)
Scrubo's Avatar
Default Starting issues
My 2000 Land Rover Discovery 2 is having some problems. Late last night I had to run an errand. Get in the car, turn the key, the lights on the dashboard come on, the engine almost starts and then it dies. Dosnt start at all. I take my key out and try again, nothing. I had to unplug the battery and plug it up back up twice to finally get it to start. I think my battery is just dying. So im going to charge my battery and try again. Anybody else think that their might be something else wrong with it?
When in doubt, hit the gas
Scrubo is offline   Reply With Quote
Old 01-02-2013, 06:19 AM   #2 (permalink)
Administrator
Never unplug the battery as a fix to anything it will only cause you other unforseen issues.
Get it started and go to the local parts store for a free charging system test. Voltage must be between 13.6 and 14.4 volts.
Need Parts?
paulgrant@mac.com or call 203-770-1699
willtillery@roverguy.com or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8, http://lucky8llc.com/
British Parts of Utah, http://www.bputah.com/
Old 01-02-2013, 06:45 AM   #3 (permalink)
Scrubo's Avatar
And if the voltage is to low?
Sent from my SCH-I510 using AutoGuide.Com Free App
Old 01-02-2013, 07:16 AM   #4 (permalink)
Administrator
Then you replace either the battery or alternator as their equip. will tell you.
Need Parts?
Old 01-04-2013, 05:00 AM   #5 (permalink)
Scrubo's Avatar
JUst a little update: The battery was fine and the D2 has been starting up as it should. Voltage was correct. I think their is a lose connection somewhere in the truck. No clue where though.
Old 01-04-2013, 07:52 PM   #6 (permalink)
'04 Discovery 2
Soggy Bottoms's Avatar
Follow the Positive lead from the battery to the starter. . .
[/SIGPIC]2004 D2 79K, Mikes High Mileage service done at 75K. SS brake extended lines, OME Lift 751F and 781 R. NitroCharger Sports with Damper, TW HD Driveshaft, Rock Sliders, Terrafirma Diff Guards F and R, LP8500 Superwinch, Dick Cepek Mud Country 265 75 R16 Tires. Hella 700FF lights, ARB Bumper. HG's and oil pump housing at 78K--POR15 Frame Treatment, 180 degree Diesel Freelander Thermostat Swap with Traditional coolant, UltraGuage.
Soggy Bottoms is offline   Reply With Quote
starting issues odom1409 Range Rover P38, Mk III and Range Rover Sport 1 06-02-2011 09:34 AM
starting issues oldie but goodie Discovery Series I 3 03-28-2011 10:55 PM
New to RR's having starting issues ltrkstr2k Range Rover P38, Mk III and Range Rover Sport 2 02-11-2011 09:22 PM
Starting Issues dalesirl Discovery Series I 1 09-28-2010 07:05 PM
starting issues lentec Freelander / LR2 0 12-02-2008 02:21 AM
SEO by vBSEO 3.3.2
