Old 07-29-2008, 06:49 PM   #1 (permalink)
mtnance's Avatar
Default Steering noise/vibration
03 Disco, 60,455 miles, nothing modified. Serviced at every LR interval at a dealer. (Verified)
Some of the time (not all), I get a hesitating rumble sound when turning the steering wheel, normally if sitting still. (As if the wheel doesn't want to turn.) There is a heavy vibration in the steering wheel during my hand pressure for a second or two, goes away if I start to move forward. Obviously either the pump, steering box, or hoses are acting up. Fluid levels okay.
If what I described sounds familiar, would you replace the pump first to see if that's the issue? I've also been told to first change out and flush the fluid, replace with Lucas Stop Leak, though I have no leak.
mtnance is offline   Reply With Quote
Old 07-30-2008, 06:59 AM   #2 (permalink)
If you have not flushed the steering, I would do that and add a bottle of Lucas to the system, this usually helps.
Old 07-30-2008, 09:58 AM   #3 (permalink)
brian4d's Avatar
Mtnance:
I tried Lucas and the sound got better, but after a month or so it came back... This prompted me to do one fluid flush after another (5 total). Every time I'd put in New fresh amber fluid it would turn black in one day. After the 4th flush I decided to try plain old (non-syn) Texico (amber in color) ps fluid. I figured "why not try what the manual recomends?" I flushed it again and wa-laa! I have amber fluid and very little noise. I can say I was starting to go a little "nuts" trying to keep the fluid amber. It took me 5 flushes in all and I had to drive about a week between flushes.
Brian Morgan
I bitch because I can, I can because I live in America.
2002 Discovery SE (Stock - No ACE, No SLS)
1995 Nissan Pathfinder SE (Sold)
1999 Chevrolet Cavalier (Red Bullet)
brian4d is online now   Reply With Quote
Old 07-30-2008, 10:07 AM   #4 (permalink)
Vavoline synthetic p/s fluid is what I use and I swear by it.
Old 07-30-2008, 11:27 AM   #5 (permalink)
2002 Discovery II SE
Me too.
I've flushed my system a few times during various repairs. When I was at a rover specialist awhile back he commented "Thats the cleanest power steering fluid I've ever seen."
Alak is offline   Reply With Quote
Old 07-30-2008, 11:36 AM   #6 (permalink)
I have a 2001 Disc . I am also experiencing the same issues. When I turn the truck on it has a humming sound. When I make a left or turn it makes a loud noise(embarrassing!). I took it to a shop and without putting the truck on a lift… just listening he told me I needed to replace my steering pump.
My steering fluid is full. Do you also recommend that I flush and use Lucas?
mursim is offline   Reply With Quote
Old 07-30-2008, 12:17 PM   #7 (permalink)
What happens if you turn to the the steering to the right?
If you don't have the noise when turning right then it is not the pump.
When did you last service the steering?
Old 07-30-2008, 12:20 PM   #8 (permalink)
brian4d's Avatar
I guess everyone's Disco is different... Val Syn made it quiet down, but not go away for me. It might be because I should have flushed it a few more times then ended up with Val Syn....
Brian Morgan
Old 07-30-2008, 12:55 PM   #9 (permalink)
Hi Mike,
I left out the right side. If I turn left or right it makes the loud noise. To be honest - I don't recall ever servicing the PS system.
Old 07-30-2008, 03:59 PM   #10 (permalink)
So how do I flush the system?
Old 08-01-2008, 03:01 PM   #11 (permalink)
mtnance's Avatar
For the person who has never flushed the system, I'd like that info as well. Sounds messy.
Disco Mike: I do not really recall the noise turning left, but I know it has turning right. That's not to say it never has (to the left). Going right just happens to be the direction I go after backing out of driveway.
Old 08-01-2008, 06:05 PM   #12 (permalink)
jmrivera's Avatar
Is the "Bleeding" procedure the best way to change the fluid?
'03 Discovery HSE7 w/ACE and SLS...
jmrivera is offline   Reply With Quote
bad steering... bushings? scottagnew101 Discovery Series II 7 06-26-2008 08:40 AM
HELP steering box woes launchpad Series Land Rovers 1 06-26-2008 03:22 AM
Steering box adjustment wimp Discovery Series II 8 07-15-2007 01:14 PM
D2 Steering box bcampbe7 Discovery Series II 6 09-23-2006 02:02 PM
power steering flush and steering box new rover girl Discovery Series II 1 10-01-2005 07:23 PM
