On several occassions now the steering wheel on my 03 DII wobbles side to side about 1/2", but then seems to clear up as I drive. Almost like it starts to oscillate but then dampens out. Seems to start as I accelerate from a stop and then usually have to slow down to get it to stop.
Steering Box loose or Front Wheel Hub shot? Any ideas? |
Ian Matthews
The usual problem is wheel balancing. Then it could be ball joints or panhard rod bushes. Then it could be shock rubbers.
A crook steering dampener does not cause wheel wobbles, it just won't hide them as well when they occur. |
Not wheel balance as it is temporary. Would think ball joints, etc. give sloopy steering with play and don't have that.
Not a warped rotor as it woobles only when accelerating from a stop and disappears when I slow down. This has only happened 3 times over the past 3 weeks. I have 50K miles. Is that the steering stabilizers life expectancy? I'll be putting an OME lift and planned on changing the steering stabilizer at the same time, so we'll see. I have also had the 3 amigos come on intermittently but not at the same time, which is why I thought the wheel hub, but I'll be happy if that's not it. Thanks all for the advice. |
New Yawker in California
Hey just a thought. what brand of Tires you have on there. and check to see if they are wearing from the inner sides. Goodyears are famous for that. I switched to Falken tires
I have 18's I love the Falken tires. and I'm not Falkin kidding ![]() |
Had Goodyear HPs when I bought it that were all scalloped and man were they noisy. Also the truck wandered and rumbled almost like out of balance, which was the dealers solution >> rebalance.
Believe it or not I found a brand new set of 4 Michelin XPC 18", as they don't make the 18" anymore. These are awesome tires and the ride is great w/ 5K on them now. Thanks for keeping the issue in mind. |
#9 (permalink) | |
discoverer
I've seen the "three amigos" from time to time as well. Steering stabilizer was my first guess until the lights started coming on. Perhaps this is a pair of problems as I notice a whirring noise on deceleration and the wobble on acceleration. Does anybody know a source for front wheel hubs less than 400/piece? Or the best deal on OME parts? BTW, this is my first post, I'm new to this forum, and new to my 03se7. Thanks in advance c |
#11 (permalink) | |
Last week I bought a set of Toyo Open County A/T's (I needed tires) and that helped a lot more... But, I agree with Disco Mike, it's gotta be the steering stabilizer since when I hit a pot hole or hard bump in the road, the steering moves quite a bit... Since it is a relatively cheap (~$70) part, that's my next move... Good luck and let us know what you find out!!!
'03 Discovery HSE7 w/ACE and SLS... |
| Thread Tools | |
| Display Modes | |
| How to remove steering wheel pre 1995 | hermanpj | Range Rover Classic | 7 | 09-08-2007 07:37 AM |
| Comments/Suggestions [Post Here] | rmuller | Tech & DIY | 29 | 04-20-2007 07:33 PM |
| 97 Disco steering wheel play? | matz445 | Discovery Series I | 5 | 01-15-2007 05:06 PM |
| DII Steering Wheel Removal? ...and hello! | DMA3 | Discovery Series II | 3 | 11-16-2006 09:32 AM |
| steering wheel | cobb ridge | Range Rover Classic | 0 | 07-23-2006 07:29 PM |
