Hi all. I have a problem with my Discovery SII and need help. The Discovery is a 1999 3.9l and has done approx 83,000km fitted with ACE and airbags. I noticed that when driving I hear this clicking noise coming anywhere from under the drivers seat to the firewall somewhere. It's a bit hard to try and track down the noise when driving. The sound is similar to the sound of your CV joints going click, click, click when turning, I know it's not this because everytime I turn nothing can be heard. I took it back to my dealer and they told me that because the car is fitted with ACE, then it's normal as the air is regulating through the pumps into the airbags and the clicking noise that can be heard is the air being purged. I though it sounds strange. This only happens when I am driving and not sure whether it is this or the gear box??. The car has and is service on a regular basis. Should I also try and book it into the dealer for a dianogstics test.
Any suggestions on what this might be. ![]() |
First off, are you sure your 99D2 has a 3.9, mine has a 4.0, or is that a down under thing?
I have a 99D2 with ACE and SLS, so I can compare mine to yours. First, the ACE make no air noise, it is hydralic to both rams. The Ace is known to make a pump noise, but it is not a clicking sound, it is more of a whirring sound. By the way, when was the last time your Ace was serviced?? The SLS make no noise at all either while driving or sitting still other then sometimes letting out a little burp of air as it resets itself. All that being said, can you better describe the noise, when you hear it, any speed, smooth or rough roads? Mike |
Hi Mike, thanks for the reply. I would tend to agree with you in saying that it is a 4.0l don't know where I got 3.9 from. With regard to when the ACE was last serviced,not sure, but looking through the service book the last service was in June 05, so another one is due. However the service was not done by Land Rover only an authorised mechanic, so they would not be aware of the ACE.
I notice the noise qutie heavy on first start up when driving. Driving varies from slow speed 40km/h to anywhere around 80 km/h (sorry not sure on the MPH figures). Driving is done on smooth road. Having taken into consideration what you have said, it does sound mechanical. I can steer OK slight whirring noises, but you have already covered that, turning is OK as well. Like I said before I can really hear it coming from under the drivers seat (RHD). By opening the window to try and pin point where the noise is coming from I can only say somewhere around the firewall or just in the engine bay. Something in the back of my mind thinks it might be the pump for the airbags not sure though. Would a Dianogstic test pick this up?? I hope this help. Let me know if you wouls like anything extra. Andy |
Andy,
Look at your ACE oil, if it is not bright red and it smells burned get back to me and I will tell you how to change it, very few shops do it and this will cause you some problems down the road. As for the power steering noise, try changing out your fluid, see if you can find some Vavoline synthetic fluid and 1 bottle of Lucas power steering additive, this will make a hugh difference. As for the noise, got an idea. Look at the front drive shaft where it hooks to the t/case, you have a double cardon set of joints instead of one joint, do they have grease fittings in them? The reason I am asking is, they are prone to failing and usually taking the transmission with it. If yours does not have the grease fittings, change it out ASAP to new u-joints with grease fittings, zerks. This may or maynot be your noise, but is it something to watch because of the damage that will come from it. As for noise coming under the drivers seat area on a R.H. vehicle, the only thing down there is a box containing the control valves for your ACE, and I don't think they can make any noise. Hope this helps. Mike |
I have seen slightly loose bolts on the steering box and other suspension parts causing the noise but that was from leaking boxes and the vehicle took a hit causing the bolts to loosen up.
Any vibration at all. |
Andy, i'm going to go out on a lim here but you may have a nail or a screw in the front tire [possibly the back but you said it sounds like front area]....if you do it will sound like a click everytime it hits the pavement...does it change with speed???
I don't think it's the SRS pump/valves as they are on the left side of the truck and the driver is on the right [in your country anyways]... Later, Dean |
#8 (permalink) | |
#9 (permalink) | |
As for the drive shaft problem, not I don't have any grease nipples. The joints that you are talking about, is it easy to replace by yourself. Andy |
#10 (permalink) |
Andy, when in doubt on the ACE fluid, you can always buy Rovers special fluid, it is just so dam expensive.
I know a lot of people here in the states the use regular power steering fluid with no problem. As for the drive shaft, I can go thru a couple of Rover forums today and find stories of the set of u-joints failing, usually taking the t/case or tranny in the process. I replaced mine at about 36,000 miles and 2 of the 8 bearing cups had bearings that had failed to the point of turning to metal powder and chunks. So when you can, pull the drive shaft and have someon rebuild it using u-joints with grease fittings. While you are under there, put a grease fitting on both drive shaft slip joints that are predrilled and capped. I wouldn't suggest you try to rebuild the jonits, they are a bugger. Mike |
