Old 08-18-2008, 11:05 AM   #1 (permalink)
Default Strange Engine Noise 2004 Disco SE7
I am experiencing what I believe to be an issue with my Disco. It only has 39K miles on it and a strange noise has developed. When accelerating under 2K RPM, the engine noise in the cabin gets louder. The sound coming from the engine reminds me of a sewing machine. I don’t necessarily hear any knocking but the engine sounds like an old tired engine. Does anyone have any ideas what may be causing this?
nashville rookie is offline   Reply With Quote
Old 08-18-2008, 12:54 PM   #2 (permalink)
Are you still in warranty, if so head straight for the dealer.
Old 08-18-2008, 01:44 PM   #3 (permalink)
Unfortunately not. Does this sound like it could be an exhaust tick or lifter tick?
Old 08-18-2008, 04:34 PM   #4 (permalink)
He did what in his cup???
DevilDisco's Avatar
Check your oil level! You may be a quart low and def go to the dealer if your oil level is good.
'04 Discovery SE7. Last of the best.
DevilDisco is offline   Reply With Quote
Old 08-21-2008, 07:12 AM   #5 (permalink)
Rover guy in Alpharetta
georgia_rover's Avatar
Actually, my '03 D2 SE7 with 35K miles, experienced a similar noise which the dealer diagnosed as a transfer case failure (a $3k repair). Luckily, I had put a LandRover extended warranty on the truck after the factory warranty expired.
If you can, get the extended warranty. The $3k that it cost was worth it was redeemed with this one repair.
Bon Chance.
"The journey of a thousand miles begins with a full tank of gas."
georgia_rover is offline   Reply With Quote
Strange vibrations when engine is off McC0mb Discovery Series I 2 04-15-2008 01:48 PM
[All] Pre 96 OBD1 Fault Codes TerryS Tech & DIY 0 01-26-2007 08:00 AM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 04:50 AM
99 4.6 is superlocked and won't reset Spring Range Rover P38, Mk III and Range Rover Sport 9 12-05-2005 05:46 PM
Multiple Issues with a 2004 Disco Shibumi1224 Discovery Series II 14 01-19-2005 02:06 AM
