The fill plug is on there really good, and its starting to strip a little on the sides, how should i get this off to fill the differential, and where should i go to buy a new one (dealer? or a land rover parts dealer online)
Scott |
'00 DII Member
Differentials & Other Land Rover Parts | FILLER PLUG DIFFERENTIAL
Less than $3.00 -> call your dealer, see what they charge. I'd hope it wouldn't be that much.
'00 DII '07 Toyota Taco War Eagle! |
First, never drain anything till you know the fill plug is loose.
Don't buy one of those junk plastic plugs, go to Expedition Exchange and buy a couple of their solid brass plugs with o-rings. You are in a fix at this point, can probably break out the plastic plug and buy a cheap replacement at a local hardware store till you get a good replacement. Mike |
'99 Disco II
here's what you do....it just might work
takes two people... One person uses channel lock plyers on the outer rim of the plastic plug, the other person uses a large flat screwdriver (the bigger the better). simultaneously turn the plug. Use a constant, steady pressure and hold it. then apply a bit more until it releases. Worked for me until I ordered a new plug. If you don't want to spend a lot of money on a fancy brass filler plug, you buy another plastic one and only put in on and take it off with the proper sized 6 point socket, it does not have to be very tight. It will last you a very long time! Actually, buy a half dozen of them and put them in your off-road kit. Who knows when they will come in handy for you or someone you're wheeling with. good luck
'99 Disco II ACE / 2" OME lift 245 75 R16 Greatyear MT/R's
| Thread Tools | |
| Display Modes | |
| Differential Global Positioning System | Expedition Nutter | Accessories | 3 | 04-02-2008 04:23 PM |
| #10 Head Bolt torque | sunshineking | Discovery Series I | 27 | 03-14-2008 10:16 PM |
| Anyone know the insides of Front Differential? | yieldsign2 | Range Rover Classic | 9 | 03-22-2006 08:47 PM |
| Broken front differential? | lostinidaho | Range Rover Classic | 7 | 10-12-2004 08:56 AM |
