Old 02-23-2006, 09:20 AM   #16 (permalink)
Nacho Libre
Hailsharky's Avatar
Originally Posted by superpowerdave
Update- Refit completed, easiest thing I ever did on a car. Twenty bucks, five minutes and three bolts. The dealership wanted $225.
Super Dave,
could you walk us through the procedure when you have a chance, and enough beer.
Cheers.
Hailsharky is offline   Reply With Quote
Old 02-23-2006, 11:34 AM   #17 (permalink)
superpowerdave's Avatar
Hailsharky-
On the underside of the steering column is a plastic gaurd protecting the wires underneath ... there are three plastic push screws that I eased out with a screwdriver. Once those three were removed the plastic piece pulled out easily.
From there, laying on the floormat looking up into the steering column, you can see the brakelight switch. On the backside of the piece there is a connector plugged into the rear. The front of the switch is inserted into a metal plate and the plunger on the switch is in contact with the brake pedal.
I turned the switch counter-clockwise which disengaged it from the metal plate, and then it hung freely which allowed me to disconnect the connector.
Installation was completed in same manner in reverse.
After the repair I looked my bad brake light switch over and found nothing wrong with it. The plunger still worked fine, so I can only assume that there was an eletrical short inside ... way beyond my expertise. Needless to say once everything was put back together the truck shifted perfectly.
On a side note, when the problem first occured I called the dealership and talked to one of the mechanics as to how I would move the truck. He walked me through a step-by-step way to bypass the brake light switch, but then cautioned me that the electrical part of the vehicle would still assume it was in park, therefore rendering the brake lights useless. In a pinch, to move the truck a very short distance, it worked fine.
That process included lifting the cover off the gear selector and depressing a small white circular button toward the rear and shifting out of park. If anyone needs info on what this looks like let me know, I'll snap photos and post them as well.
superpowerdave is offline   Reply With Quote
Old 10-18-2007, 03:36 PM   #18 (permalink)
I had the same issue with my 00 disco and this thread saved me!!! I went to land rover, bought the switch for 15 bucks, followed the instructions that you guys provided........... 5 minutes later, Im back on the road. This site has saved me thousands over the past 2 years.
Supreme05 is offline   Reply With Quote
Old 10-18-2007, 03:49 PM   #19 (permalink)
you will save a lot more if you get rid of your rover. they're cursed.
2001 Discovery SE7 -- Sold Thank God!!! Toyota Only Baby.
JMan is offline   Reply With Quote
Old 10-19-2007, 11:24 AM   #20 (permalink)
JMan, if you don't mind, please stop making comments.
You already shared your views on a thread that should have been deleted.
Many people on this forum, including myself, LOVE our LR's, quirks and all. Unfortunately, it seems like you've had a bad time, but we really don't care, now that you've sold it.
Go join a Toyota Forum.
Happy Roveri.....i mean, Take Care.......
John-Robert
2003 Land Rover SE7
- Stock Hardon Karmon speakers
- Stock Navigation System
- Cold Weather Package
- SLS
- ACE
johnnybob06 is offline   Reply With Quote
Old 10-31-2007, 11:38 AM   #21 (permalink)
A real Hillbilly from KY.
Dragunov's Avatar
I have a D1 '98 and a DII '99. They're the most dependable vehicles I've ever owned, and I've owned a lot.
DRAGUNOV -------> Don't run from me... You'll just die tired.
'99 Discovery II
'98 Discovery I
'89 RRC "The Lizard"
RoverAddiction
Dragunov is offline   Reply With Quote
