hello, I am the owner of a 2003 Discovery and can't get the shifter out of park. any help would be VERY appreciated...
a little background: I was hit on the rear driver's side a few days ago and the impact busted my rear bumper so much that the tail light wires were disconnected. I was able to drive it still until yesterday when the stuck shifter happened and now I'm stranded in a parking garage. anyway, I read a few posts and figured the exposed tail light wires shorted the brake light switch so I bought a new one and replaced it - didn't work. is there any way I can get it out of park just enough to drive it to the dealer? thank you in advance... |
'99 Disco II
Remove knob from shift lever (just pull straight off very hard)
Remove the cover from the shift lever (just pry it up i beleive) locate the solenoid to the right of the lever (little cyliner with a nub that sticks out to prevent shifting). remove it (i forget, but I think it is just a couple screws. you can either leave it out or figure out what is wrong and replace. either way, with this solenoid removed, you will be able to shift out of park the problem probably does not lie in the solenoid itself (most likely in the micro switch under the brake pedal) This will get you moving agin without too much trouble though very easy to do hope this info is complete and helps sorry if it is not, it has been a while since i was in there Wimp
'99 Disco II ACE / 2" OME lift 245 75 R16 Greatyear MT/R's
| Thread Tools | |
| Display Modes | |
| Stuck in park | luckesc4vett | Discovery Series I | 7 | 06-08-2008 12:41 AM |
| Stuck in Park | JimN | Discovery Series II | 0 | 07-04-2007 12:45 PM |
| Stuck in Park...Help! | 9dawgs | Discovery Series I | 18 | 08-04-2006 11:29 AM |
| Stuck in Park - Replacing Safety Switch - Help! | disco2maine | Discovery Series II | 8 | 06-24-2006 09:18 PM |
| Stuck in Park | Dwhitlock | Range Rover Classic | 2 | 09-09-2004 05:53 PM |
