Old 06-22-2006, 08:51 PM   #1 (permalink)
Default Stuck in Park - Replacing Safety Switch - Help!
While in park(and no radio on so I can hear) I push on the brake pedal, and I cannot hear the saftey switch disengage on the shifter. I took off the shifter covering and saw the golden cyclinder to the right of the shifter. I pressed the brake pedal and held my finger on this and did not feel or hear the clicking noise.
My friend has a Disco2 and I tested the same on his working shifting and have come to conclusion that my safety switch is gone. How easy is this to fix and what is the part called??? Thank you
disco2maine is offline   Reply With Quote
Old 06-23-2006, 06:04 AM   #2 (permalink)
4x4 Adventure Gear
John C's Avatar
Brake switch: it's behind the brake pedal and in an emergency it can be bypassed by jumping two wires.
Does you transmission shift into park with the brake pedal pushed down? Do your brake lights work?
We have the brake switch (I always carry one or two extra ones with me) and it's very easy to replace.
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 06-23-2006, 06:17 AM   #3 (permalink)
John's Avatar
Oh no, not the dreaded listening for noises in car parks (in my case while eternally waiting for my wife to shop).
I do this so often and even while driving and generally I end up a nervous wreck imagining that the thing is about to disintegrate.
John is offline   Reply With Quote
Old 06-23-2006, 06:19 AM   #4 (permalink)
the thing is the brake lights do work, doesnt this rule out the brake switch?
Old 06-23-2006, 06:22 AM   #5 (permalink)
The transmission is in park now and I can't shift out of it. You are supposed to hear that safety switch click when you depress the pedal do disengage the piece that locks the teeth in place so you can shift out of park
Old 06-23-2006, 04:43 PM   #6 (permalink)
Seen a few shifters go bad.
If it is the switch its pretty cheap to fix.
push down on the brake pedal and pull it out and make sure to keep the pedal in until the new switch is installed.
Buy yourself a long two feet philips head screwdriver. It acts as a brake pedal depresser and can be used for other stuff.
Old 06-23-2006, 06:17 PM   #7 (permalink)
So... I got a new brake switch... installed it... still doesn't do the clicking noise thing when the pedal is depressed. What else could this be? The only good thing is I can press the silver button underneath the shifter assembly to manually put it in reverse, drive , etc so i can at least drive it to the dealer if must be but i rather try to see if we can figure it out to save some cash. The brake lights still work too when i put it in drive manually like that too. This is pretty weird........ any ideas on what to try next?
Old 06-24-2006, 10:58 AM   #8 (permalink)
Otherwise known as STEVE
The solenoid is probably bad. The fact that your brake lamps worked all along suggests that the brake switch was fine. The solenoid/acutator/shift interlock as they are called can sometimes fail- as apparently yours did.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 06-24-2006, 09:18 PM   #9 (permalink)
I would also check all your fuses.....i think i read something about it in one of the "notes" in the owners manual, i suspect it's also hooked up to something else on the circuit so you may have another problem alltogether.....
later, Dean
6cuda6 is offline   Reply With Quote
