Old 02-24-2008, 12:36 PM   #1 (permalink)
dubb57
Default Style of Jack and safety stands
What style of Jack and safety stands does everybody use?
What would you recommend to a newbie? Or is the stock jack enough?
Weight requirements and all that jazz.
I want to start working on the rover but need a few things.
dubb57 is offline   Reply With Quote
Old 02-24-2008, 03:20 PM   #2 (permalink)
XtremeMarine's Avatar
I tend to vary depending on the job. If I just need to lift a corner, I use Kobalt 2 1/4 ton jack stands, along with a Kobalt or Craftsman Industrial floor jacks. When I'm doing something that requires the whole truck off the ground; I use 6 ton Snap-On jack stands under the frame, with the Kobalts as safety's under the axles. The Snap-On's are built like tanks, probably the toughest stands I've ever owned. For off-road, I have a 5 foot Hi-Lift, with an off-road base. Never would trust the stock jack for anything but an emergency side of the road tire change.
Originally Posted by Elemental
Some guys play hard to get, I play hard to want.
Old 02-24-2008, 04:06 PM   #3 (permalink)
Are you just going to use it for when you have a flat tire, if so stay with the factory jack. If not, depending on what your are going to do a floor jack may be a better idea.
Old 02-24-2008, 04:12 PM   #4 (permalink)
dubb57
Well for starters, I want to take the driveshaft off to have the Ujoints replaced.
I figured I needed it for other maintenance as well.
Old 02-24-2008, 04:12 PM   #5 (permalink)
dubb57
Thanks Xtreme for the info.
Old 02-24-2008, 04:27 PM   #6 (permalink)
No Problem. Just my.02, man. Anything to help.
Old 02-24-2008, 07:29 PM   #7 (permalink)
dubb57
Thank u 2 Mike. Didn't want to leave you out.
Comments/Suggestions [Post Here] rmuller Tech & DIY 29 04-20-2007 07:33 PM
