Old 07-06-2008, 10:22 AM   #1 (permalink)
Default Suggestions please!! Coolant Issue
Hey all!
I've got an issue going on with my Disco II - and I fear that it's actually common and expensive
Anyone else have an issue coolant dissapearing? I'm not sure where it's all going because I seem to be adding much more than what is in the "puddle" underneath the truck. So, it can't be evaporating, so is it getting burned off somewhere? I've done some research and it sounds like it could be the water jacket or a cracked block... Oddly enough it doesn't burn hardly any oil, and there isn't a milky like mixture in the coolant res. - it's just bone dry!
Any ideas? It's got 70K on it and this would be the first "major" mechanical issue I've experienced...I guess I got lucky!
Thanks
Chris
roversne is offline   Reply With Quote
Old 07-06-2008, 12:09 PM   #2 (permalink)
'00 DII Member
auwesman's Avatar
Bone Dry??? That's a LOT of coolant to be loosing, and very dangerous. Take it to a shop (any shop really) and get your coolant system pressure tested. That's where I would start.
How often are you having to fill it up....how much each time?
'00 DII
'07 Toyota Taco
War Eagle!
auwesman is offline   Reply With Quote
Old 07-06-2008, 12:19 PM   #3 (permalink)
Just go have the coolant system pressure tested, you'll find the problem real fast.
Don't waste time reading replys, longer you put this ove the more expensive it can and will be.
Coolant hose rupture JimN Discovery Series II 4 07-06-2008 12:18 PM
Massive coolant leak issue D. Hammack Range Rover P38, Mk III and Range Rover Sport 1 05-20-2008 07:21 PM
coolant flush and refill. wtf. Jupiter Rover Discovery Series II 8 05-04-2008 08:57 PM
95 SWB smells like coolant and blows air bubbles kkrover Range Rover Classic 33 02-15-2008 07:34 AM
Time is running out for Moab travel management comments jimfoo The Lounge 2 11-13-2007 01:27 PM
