One of the clips on a sunroof shade is broken. Are these easily replaced?
Thanks, Rich
Future: Something from Land Rover when the depreciation hits a reasonable level ![]() Current: 2000 Discovery II ![]() Former: 1997 Discovery I ![]() 1990 Land Rover
Look hard and try to find the other piece. If you find it use crazy glue and let it sit for 24 hours before you hook it back on. I did this and it's stronger than the orginals. If you can't find it I've heard of some people buying metal type clips from Lowes or Home Depot and attaching the makeshift metal clip to the remaining plastic by using small screws. Either way I believe it's about $300US to buy a brand new one. No thank you....
Brian Morgan I bitch because I can, I can because I live in America. 2002 Discovery SE (Stock - No ACE, No SLS) 1995 Nissan Pathfinder SE (Sold) 1999 Chevrolet Cavalier (Red Bullet) |
HeadlinerExpress
Theirs a lot involved replacing the Retractable Sunshades in your disco's.
In order to replace them you will need to: 1) Remove the Headliner Board - Completely 2) Remove the Bottom Sunroof Lower Tub, drain tubes and Sunroof Motor 3) Remove the Retractable Sunshade to either repair the one broken or replace the whole unit. 4) we have been replacing just the broken one with a used part for $90 dollar while we install new Headliners for our Customers. 5) if you have any other questions feel free to either email me or give me a call i will walk you through the problem. Bill
Headliner Express Headliner & Sunroof Repair Central Florida 68 Unimog TLF-8 Firetruck 65 Unimog Radio Box www.HeadlinerExpress.com www.LandroverHeadliner.com |
#9 (permalink) |
Back in a Series LR after 25 years :-)
Rover Connection-Sunroof Clip
I remember reading here that someone was looking for these. Stumbled across it looking for a good price on O2 sensors.
Back in a LR after 25 years!!! 71 Series IIa 88 01 D2 "BackInA88" on all the other LR forums (Sign up here first and couldn't think of a good handle at the time! )
#10 (permalink) | |
Need to hit up a junkyard and replace the whole part (shade and all)! Jonathan
'03 Discovery HSE7 w/ACE and SLS... |
#11 (permalink) |
HeadlinerExpress
No one makes a replacement clip as of yet, Its easier to replace one side with a used part versus spending endless time driving around from hardware store to Hardware Store using up valuable fuel, running around in junk yards, spending money on lunch. you will spend more money just looking around then what a used replacement part cost.
Granted A New part cost a little over $300 from Landrover Parts Department, used parts are available to resolve the problem, just your labor to install. let me know how i can help! Bill
#12 (permalink) |
New Yawker in California
I purchased my disco and it had a clip broken, so I figured eh. I'll just go by the clip.
BUZZZ. wrong answer. Well what I ended up doing was pretty simple. I got a piece of sheet metal. cut it to the size of the hook, bent the end so it latches. then I drilled a small hole in threw the new piece and the part on the disco. put in a very small bolt and nut. I even went so much as to spray paint it flat black. so it would match. This was about 3 years ago and it's still going strong. I will see if I can take post a picture of it |
