Old 06-21-2008, 12:42 PM   #1 (permalink)
Exclamation Immobilized and don't have a remote...
IMMOBILIZED AND NO FOB!!!!!!!!
This is sad that this will be my first post but here we go...
I have a '99 Disco Deuce and do not have the remote. Bought her used so no worries, have a key good to go. Now for the problem, didn't realize that she would superlock but she does. I drove her two days ago and parked in the driveway and locked as usual however, I left the two back windows down a bit since it's getting quite hot. Go to get in her today, with key only, and the alarm doesn't shut off. No biggie, key in ignition and she turns off, dilemma; security light remained on and now it is completely locked down. Won't turn over, transmission is locked down...
What is it that I should do to enable me to drive again??? Any suggestions will be taken and used. Thank you all in advance and please have fun with this one, I should have gotten the damn remote while I was thinking about it earlier this year!!!
Last edited by Gulfviews14 : 06-21-2008 at 05:28 PM. Reason: Need to find it later...
Gulfviews14 is offline   Reply With Quote
Old 06-21-2008, 03:06 PM   #2 (permalink)
First try using your key lock and unlock the drivers door 3 time slowly over 10 or 12 seconds, see if that resets the looks.
By the way, the Super lock only works when you double lock the doors with either a key or the remote, singak turn of the key won't shut her down.
Old 06-21-2008, 03:15 PM   #3 (permalink)
When you say unlock, must I lock and then unlock or just turn to the left three times within 10-12 seconds? I had her superlocked, double turn.
Old 06-21-2008, 05:18 PM   #4 (permalink)
I just disconnected the negative contact. Gonna leave it overnight to see if the system resets itself. I will reattempt the key reset but it is not the original. Put in a request at the Mobile, AL Land Rover since they are the closest to me. Thank you for your help and suggestions.
Old 06-22-2008, 05:49 AM   #5 (permalink)
Lock and unlock, just as I said in my last post.
Old 06-22-2008, 06:32 PM   #6 (permalink)
Steph's Avatar
Open the hood, and press on the fuel cut-off switch...Passenger side,on the firewall, beside the engine, looks like a rubber flashlite...anyways, press the top of it and try it.
Disconnecting the battery isn't a good thing, cause you might lock up your radio and need the security code to unlock it.
Knowledge is only really worth anything when its been experienced first hand. If you heard it from a guy who heard it from a guy.....nevermind and keep it to yourself.
Steph is offline   Reply With Quote
