Old 05-13-2008, 01:31 AM   #1 (permalink)
greekdisco's Avatar
Default suspension/tires/wheels/bumper/ and more ?
Curious of what yall thought of me possibly putting...
- RTE 2 inch lift RR3 in the rear / RR4 in the front
- Bilstein Shocks
16x7 black steelies
- RTE bumper with skid plates
and either BFG MT's or AT's i would like to have 265/75/16 which are 32's (im pretty sure)
- 9000K lb warn winch
- odyssey battery
this is for a '03 disco II, i guess my other questions are would i run in to other driveline problems with 32's and a 2in lift, would it be wise to do any more mods to ensure reliability. I wont be running it on hard core trails, i just hate the way it looks right now and want to have a kick ass disco II
Comments highly recommended !!!
greekdisco is offline   Reply With Quote
Old 05-13-2008, 05:39 AM   #2 (permalink)
Before you do anything, go get your front drive shafts 2 greaseless u-joints replaced.
As for the lift it is fine except for the shocks, RTE will also tell you, use OME's HD shocks which are 1/2" longer then the Bilstein's.
For the tires you have mentioned, use 16X8" wheels, not the 7".
Add a set of stainless steel extended brake lines.
I am not real keen on front skid plates on D2's, which will greatly restict the air flow, that already run way to hot.
Throw in a new OME steering stabilizer and you should be fine.
Old 05-13-2008, 12:28 PM   #3 (permalink)
greekdisco's Avatar
thanks, it sounds good
