SVS Electrical failure...134 - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 2 (permalink) Old 02-13-2012, 01:03 PM Thread Starter
Quoted: 0 Post(s)
Ok so my three lights came on, I had the codes pulled and the one that came up was 134 Shuttle Valve Switch Electrical failure. I've done some searching and I haven't found anything referring to 134 or Switch failure. I've seen supervision failure and electrical supervision failure...Are these the same where i could fix them with the sticky at the top of the page? also got a p1000 anti theft alarm code
KCSuppressors is offline
post #2 of 2 (permalink) Old 02-13-2012, 02:18 PM
Quoted: 0 Post(s)
You are going to need to post all the codes for the ABS as I do not recognize 134 as a SVS code. I believe the SVS switch code is 114 for the SVS Supervision.
The common problem is the solenoid pack ground pin goes bad and the fix is to bypass. We elected to replace the solenoid pack, SVS and SVS seals (from Falcon Works) instead of adding one more wire to worry about.
I would recommend reading through the link below and see if your codes match.
ABS Mod - LAND ROVER CLUB V.I.
2003 Land Rover Discovery 125K with high miles service complete
borchera is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
SVS question?? ABS ?? Vixious2001 Discovery Series II 4 01-03-2012 08:46 AM
3 amigos : Code 4114 --4114 Shuttle valve switch failure electrical supervision lowest bidder Discovery Series II 13 12-12-2011 06:48 PM
ABS SVS fix cris Discovery Series II 4 05-12-2010 08:27 PM
DII ABS SVS removal cris New Member Introductions 0 05-10-2010 10:10 AM
Terminal Gremlin infestation - Major electrical failure. Black Magic Discovery Series I 14 02-24-2007 04:41 PM
You may post new threads
You may post replies
