» Sponsors
» Sponsors
Old 01-06-2009, 06:51 PM   #1 (permalink)
Default Tail Door Speaker
I have two tail door speaker housings. One has two speakers and plugs into the existing harness, the other has what looks like a small booster amplifier attached to the unit between the two speakers and has a different plug that does NOT mate with the door harness. I can not find any reference to this second setup in RAVE.
Any ideas??
Rich
Future:
Something from Land Rover when the depreciation hits a reasonable level
Current:
2000 Discovery II
Former:
1997 Discovery I
1990 Land Rover
csa02221862 is offline   Reply With Quote
Old 01-06-2009, 08:14 PM   #2 (permalink)
Thats your factory subwoofer...or supposed to be, there are 2 6.5" speakers in that housing thats at the end of the rear door pocket. I only know of one housing back there...unless someone's added one to yours, you might throw up a few pics...I'm a bit confused about the second harness or whatever....In my opinion the factory subs are terrible. Mine fell all to pieces and I ended up swapping them with some other speakers for a bit, then I removed then all together. I've got polk audio component speakers and my stereo sounds a ton better since i removed the subs...might be something to think about
BamaDisco03 is offline   Reply With Quote
Old 01-07-2009, 09:24 AM   #3 (permalink)
Here are the two speaker packages the part number on the amplifyer is: A 4025 J7. the on with the amplifyer has a 6 pin connector, I'm sure the two extra pins are for + and ground.
Rich
Future:
Current:
2000 Discovery II
Former:
1997 Discovery I
1990 Land Rover
Old 01-07-2009, 09:31 AM   #4 (permalink)
I will need to replace the two speakers regardless of which housing I install. I am happy with the premium system that is installed. I would like and opinion on these two setups and a recommendation on a speaker replacement.
Thanks,
Rich
Future:
Current:
2000 Discovery II
Former:
1997 Discovery I
1990 Land Rover
D90 Tail Light Electrical Connector D90Boston Defender 3 11-25-2006 07:34 PM
Rear Tail Lights & Break Lights cgaulding Discovery Series I 2 06-17-2006 11:46 AM
Upgrading DII tail lamp nighttime running lights keptin Discovery Series II 6 12-29-2005 03:46 PM
2002 Disco Tail Lights DiscoBoi2002 Land Rover Parts and Accessories 1 10-13-2005 09:17 PM
Converting to 03'-04' DII tail lamps ibjettin Accessories 0 09-21-2005 01:48 AM
