» Sponsors
» Sponsors
Old 12-19-2008, 06:16 PM   #1 (permalink)
discoverer
reverendALC's Avatar
Default tail light downgrade
are both disco2 tail lamp styles interchangeable?
i have an 03 with G4 lamp guards, and i think they fit far better on the 99-02 lamps. i'm aware the bulb configuration is significantly different, but i'm capable of handling that.
does anybody know if 99-02 lamps can be fitted to an 03-04?
thanks
current:03se7 previous:97se want:nothing else
06 RRSC 20" alloys - G4 genuine lamp guards - centric slotted rotors & akebono pads
reverendALC is offline   Reply With Quote
Old 12-19-2008, 06:18 PM   #2 (permalink)
Reptile Expert
i dont see why not, wiring is the only issue. the bolt patterns are the same
04 D2
stolenheron is offline   Reply With Quote
Old 12-19-2008, 06:18 PM   #3 (permalink)
jake_ak_cent's Avatar
with enough work, anything can be done.
____ROVER____
(Roll Over Very Extreme Rocks)
JAKELRD1 96' D1 "TK"
jake_ak_cent is offline   Reply With Quote
Old 12-19-2008, 09:07 PM   #4 (permalink)
Deployed OIF
ArmyRover's Avatar
I agree with Stolen just straighten out the wiring and you should be straight.
of them." unknown quote.
(offending Austrailians since 2008)
http://www.wheelinrovers.com/
91 Range Rover Classic
89 Jaguar XJ6
Old 12-21-2008, 10:41 AM   #5 (permalink)
muddy-bugger's Avatar
Gallery: 4
yep they should fit fine as a mate of mine had the 99-02 style and changed to the new ones but the lamp layout is different in that
the indicator on you disco are up high in the older style the indicator were in the bumper all you would have to do is re wire that small section and it should all be good
let us know how you get on!
good luck
muddy-bugger is offline   Reply With Quote
Old 12-22-2008, 11:28 AM   #6 (permalink)
naterover's Avatar
if your wanting to down grade i want to upgrade lets trade. my 99-02 tails for your 03-04's
"It takes a big man to cry, but it takes a bigger man to laugh at that man."
Nathan Pedigo
00' Land Rover Discovery II SE7
naterover is offline   Reply With Quote
access to tail light and the parking light in front? yatzi1980 Discovery 3 / LR3 3 12-31-2008 12:34 AM
Left Rear Tail light Assembly for a 99 D2 Disco Mike Land Rover Parts and Vehicles Wanted 0 04-19-2007 01:38 PM
D90 Tail Light Electrical Connector D90Boston Defender 3 11-25-2006 07:34 PM
DI/DII question: tail light assemblies/panels SCSL Discovery Series II 4 11-17-2005 10:01 AM
'00 RR Tail light covers... Paul K Land Rover Parts and Accessories 0 01-10-2005 03:28 PM
SEO by vBSEO 3.3.2
