Old 05-01-2005, 04:18 PM   #1 (permalink)
Default Delete
Delete
millburn is offline   Reply With Quote
Old 05-01-2005, 04:42 PM   #2 (permalink)
Super Moderator
02disco2's Avatar
Wish I could help you, I am 5'9" and I have my seat all the way back! I wish mine would go even further!
Land Rover-less.
2006 Infiniti QX56 - Loaded
2002 Discovery II SE - SOLD!
Old 05-01-2005, 06:03 PM   #3 (permalink)
Default Sorry... I am 6'2" as well....
I fit better in the 2004 than the 2000....
They both are awful with regards to leg room
2000 LR SE 101k Miles and growing....
2004 LR SE7 3500 Miles and growing....
1995 Harley Fatboy - 16k Miles and growing....
curedude is offline   Reply With Quote
Old 05-01-2005, 06:20 PM   #4 (permalink)
Super Moderator
Disco's Avatar
I did read somewhere where this conversion had been done quite easily, with a manually operated seat. I'm not sure if it will work with an electric seat. Anyway, the manual seat goes back 5 clicks, and forwards 13 clicks. What you need to do is just remove the seat and turn the rails around, reinstall seat.
Old 05-01-2005, 09:44 PM   #5 (permalink)
rovering??
1st rover's Avatar
i did this on another car for a friend.
u pull out the seat and reset the track about 2 to 3 inches back.. u may need to drill hole or 2 but it is doable. on a difficulty scale of 1 to 10 i would rate this at 3
-Nikunj
1993 Range Rover Classic LWB
1995 VW JETTA
1st rover is offline   Reply With Quote
Old 05-02-2005, 04:00 AM   #6 (permalink)
BSWE87's Avatar
I am 6' 5" and absolutely fit and sit well in a 98 Discovery I.
I could not enter or exit military jeeps (old) or the military hummer with combat boots on. I do have some getting out issues with the DI when I where hiking boots, just like the hummer. Loafers -Okay.
But sitting. - just fine...
Discovery I
1998
85,000 Miles
Cobar Blue
BSWE87 is offline   Reply With Quote
Old 05-02-2005, 05:18 AM   #7 (permalink)
Super Moderator
Disco's Avatar
With a bit of modification, entry via the sunroof could be achieved!
Old 05-02-2005, 06:58 AM   #8 (permalink)
Wheeler
SCSL's Avatar
Originally Posted by millburn
I'm 6'2" with long legs and I need more room in my '04 Disco. Any suggestions to get more leg room?
Cheap solution: go to 'The Better Back Store' (or local equivilant) and by a lumbar support for your lower back. I found the Disco seats had poor lumbar support so I went shopping & found a lumbar support made out of that tempur-pedic stuff. Made my back feel MUCH better,,, and prevents you from slouching into the seat (which extends your legs farther than they would normally go) which effectively gives you more leg-room (not to mention better posture). Only drawback in winter is that they tend to stiffen up in the cold,,, but they warm up soon & become more flexible.
