» Featured Product
» Sponsors
» Sponsors
LandRoversOnly.com is the premier Landrover forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 11-23-2009, 07:52 AM   #1 (permalink)
Beach Bum
brian4d's Avatar
Default TC/ABS only with 3 tone
The subject line says it all. ABS/TC only and the tone beep. I turned it off and the lights went out. I checked and my rear pads are on their last leg. Questions is generally speaking do warn pads throw the lights. I'm sure the answer is yes but I needed to double check.
Brian Morgan
brian4d is offline   Reply With Quote
Old 11-23-2009, 08:00 AM   #2 (permalink)
jycsalas's Avatar
Low pads will not trigger the lights as the DII does not have brake pad sensors. However squeaking brakes caused by low pads can disrupt the reading of the wheel sensor and trigger the lights.
If your pads need replacing then replace them. Unfortunately you wont know what fault has been triggered without proper diagnostic readings.
~Josh
2003 Discovery S (64k miles)
www.landroverclubvi.com
Mods: Oil Pressure Gauge, ScanGaugeII, CDL, Electric CDL Actuator, RoverRacks Rear ladder, Limb Risers, ToddCo Front Drive Shaft, DI Wiper Arms, G4 Upper Rear Lamp Guards, No Amigos since 11/09
Coming soon:
Install Greg Davis rear bumper, Replace 4 ball joints, Replace belt tensioners and pulleys.
For the future:
.... wait and see....
jycsalas is offline   Reply With Quote
Old 11-23-2009, 09:08 AM   #3 (permalink)
nasa25's Avatar
from experience these are thrown due to dirty speed sensors.....take a power washer to the wheel wells every time you wash your truck and it should be ok.
nasa25 is offline   Reply With Quote
Old 11-23-2009, 09:25 AM   #4 (permalink)
jycsalas's Avatar
Do you mean the part of the sensor inside the hubs get dirty or the plug connections at the wheel wells?
~Josh
Coming soon:
For the future:
Old 11-23-2009, 09:29 AM   #5 (permalink)
Beach Bum
brian4d's Avatar
The pads were loud that day. It seems the more warn they get the louder it gets, would make sense. Thanks for the input guys.
Brian Morgan
Old 11-23-2009, 09:52 AM   #6 (permalink)
nasa25's Avatar
plug connections at the wheel wells.....I know it sounds like a stupid remedy but since it worked for me I figured I would share.
Old 11-23-2009, 10:17 AM   #7 (permalink)
jycsalas's Avatar
Oh NO I think you are right on. I just wanted to clarify what you meant. That maintenance is easy to do and highly recommended. Especially since they no longer make those sensors with the plugs. New ones have to be straight wired into the SLABS ECU.
~Josh
Coming soon:
For the future:
Old 11-23-2009, 10:22 AM   #8 (permalink)
nasa25's Avatar
yeah I recall that change awhile back. I think that both of my front speed sensors are the new style (I replaced them when I changed out the modulator) and the rear ones are the old style which have been good thus far.
Old 11-23-2009, 10:56 AM   #9 (permalink)
323jamie's Avatar
I havent heard a tone beep on mine I have these lights on what speciffically am I looking or listening for?
Bless the Military, Border Patrol, and Lawenforcment and family's that support them. They protect us while we sleep and express our freedoms as US citizens.
We are free because we have the second amendment once this is gone we will have none, make and impact get involved with you towns political views.
http://manhattandeclaration.org/imag...eclaration.pdf
323jamie is offline   Reply With Quote
Old 11-23-2009, 11:19 AM   #10 (permalink)
jycsalas's Avatar
Well what you need to do is get the codes read. Are they on now? Are they intermittent?
~Josh
Coming soon:
For the future:
Need help making a Land Rover Ring tone fivespddisco General Land Rover Discussion 5 11-19-2009 03:26 PM
Ticking (Tone?) noise under hood... MARGRETTE Discovery Series II 14 04-25-2009 11:49 AM
SEO by vBSEO 3.3.2
