Temp (reality) Check - Land Rover Forums : Land Rover and Range Rover Forum
 3Likes
post #1 of 153 (permalink) Old 03-12-2017, 09:51 AM Thread Starter
Quoted: 61 Post(s)
04 135k mi
Head gaskets done not too long ago.
New tstat at that time.
New radiator about 2 years ago.
Running at about 204 after driving/idling.
Drops to about 197 when rolling down the road.
Am I flirting with trouble?
What would be my steps 1, 2, 3 to start getting that temp down?
Everything seems to be in good working order - just seems a little hi on the temp readings and in Arizona it's only gonna get hotter.
sobieski is offline
post #2 of 153 (permalink) Old 03-12-2017, 10:20 AM
Quoted: 290 Post(s)
Haven't seen you here in a bit. Good to know you're still kicking around.
Try these, in this order. One at a time. Except the last one.
What thermostat did you use? I'd suggest the low-temp unit. It's MotoRad part #439-180 . It will give you some headroom at idle with poor airflow, like sitting stopped on hot asphalt on a bad day, or under a heavier load. It just gives you an extra few degrees of temp climb before getting to boil over. I have read that they flow a little better but I don't know if that's true. Some sort of internal spring loaded bypass. Not sure on that.
All radiators are not alike. If you bought a cheap one, or just ended up with one and over-paid, It won't perform like a good one. The Nissens is a very good replacement and under $200. The others are all pretty much Chinese. maybe you have a local radiator shop that can flow test it. I've seen under the tanks on some of those cheap imports and it looks like they have monkeys soldering the cores to the ends. No wonder they don't flow.
You might try a water pump replacement. Use only a premium aftermarket with the metal impeller. Delco Pro is $65 on Rockauto. Impellers can deteriorate due to the effects of cavitation and will eventually reduce coolant flow.
If you're still getting warm, an auxiliary oil cooler will definitely help. Right now, the system is relying on conduction internally to cool the oil. This places a load on the primary cooling system. Running the oil through a separate system relieves a big burden from the radiator, freeing it up to carry more load.
Also, check your aux electric fan. They are a high failure rate item. It should kick on at startup for a moment and any time the AC is switched to max.
CT090 is offline
post #3 of 153 (permalink) Old 03-12-2017, 10:23 AM
Special Agent
redtruck12's Avatar
Quoted: 121 Post(s)
Garage
Hey!!!! Have not seen your name in a while ... Welcome back?
It's a little warmer than preferred in my opinion but not terrible.
From your description it gets better at speed (speed means to me more airflow through the rad) maybe have a look at the fan clutch? Did you replace the water pump last year?
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is offline
post #4 of 153 (permalink) Old 03-12-2017, 10:41 AM
Quoted: 290 Post(s)
Yeah- forgot the fan clutch (how could I?!)
197 isn't out of line. If it has a 192 stat in it, it's going to work within a few degrees of variation. And if the temp read is off of the OBD, you'll also get a couple degrees of variation from true reading there. One of the biggest problems is the Rover grille. It looks cool but blocks alot of airflow.
CT090 is offline
post #5 of 153 (permalink) Old 03-12-2017, 10:42 AM Thread Starter
Quoted: 61 Post(s)
Hey guys. I have been hanging out - just watching the forum but not posting as there are a lot more experienced folks out there.
Anyway,...
Used the 180 degree tstat.
Replaced water pump about two years ago (pre head gasket).
I think I got the radiator from Atlantic British.
Have an oil cooler already.
Aux Fans are perma-on with the AC on.
Viscous clutch "feels" good - lots of resistance when turning by hand - but, no, I didn't replace it last year.
sobieski is offline
post #6 of 153 (permalink) Old 03-12-2017, 11:55 AM
Quoted: 290 Post(s)
Are you absolutely certain you have the 180 stat? At no load idle with good air movement you should be right around that temp. The engine really isn't creating alot of heat in that state and shouldn't be over-taxing the cooling system. Try letting it idle and see where the heat settles at while idling. Then raise the RPM up to about 2K. If you get a temp drop, you probably have an eroded impeller. If not, it's probably the stat. How are you measuring the temps?
I remembered this thread and I bookmarked it. It's a discussion about the Motorad and the Rover 180 stat. There are comments from users consistent with the results you are seeing. Buy the genuine grey land rover 180 thermostat - Land Rover Forums - Land Rover Enthusiast Forum
Internal temperatures are much less concerning than overheats. Your engine will operate just fine at 220 degrees. Not optimally, but it'll run just fine and for a very long time. If you have a 50/50 blend, your boiling point will be at about 225. A degree under boiling and your system operates. At boiling, it stops. So obviously you want to stay as far away as you can.
How is your oil cooler set up? Where is it getting oil from and how is it returning it?
CT090 is offline
post #7 of 153 (permalink) Old 03-12-2017, 01:24 PM Thread Starter
Quoted: 61 Post(s)
Yes sure on the tstat.
Oil cooler is at front down low across front of raidator.
Idling 199 - 201.
sobieski is offline
post #8 of 153 (permalink) Old 03-12-2017, 03:08 PM
Quoted: 290 Post(s)
Idling 199 - 201.
Are you measuring it with a separate thermometer that is known accurate?
How is that oil cooler plumbed in?
CT090 is offline
post #9 of 153 (permalink) Old 03-12-2017, 03:29 PM Thread Starter
Quoted: 61 Post(s)
I am using an obd port tool.
Oil cooler is stock.
It is so random.
But definitely seems hotter while driving, as opposed to idling.
Sounds like I need to keep an eye on it and either replace the clutch or radiator or both if I reach temps beyond my tolerance.
sobieski is offline
post #10 of 153 (permalink) Old 03-12-2017, 03:53 PM
Quoted: 290 Post(s)
That's the trans cooler.
Pull the stat and put it in a pan. Put heat to it. You can get a very accurate digital thermometer at Walmart for $10. Find out for sure where the unit is opening. If you see it opens at 195, you found your problem. Before all this, use that fancy new thermometer on the truck to confirm what the OBD is showing.
Temp will go up when driving. The engine is creating more heat. You're getting past where the radiator can effectively remove heat if the temp climbs too much.
Here's an experiment- drain the cooling system. Do it a few times to get as much out as you can- drain and fill. Or pull the block plugs. Fill with straight water, preferably distilled. If temps come down over what it was doing with AF, you probably have radiator blockage. Straight water is more thermodynamically efficient, but has a lower boiling point. In range, it will take more heat out of the system. But if you get a really hot day and you're under a heavy load and it hits 212, you're done.
CT090 is offline
post #11 of 153 (permalink) Old 03-12-2017, 04:16 PM
Ian Matthews
p76rangie's Avatar
Quoted: 161 Post(s)
04 135k mi
Where are you located. Sounds like a warm climate if you have the air-con on all the time. None of those figures are a concern if you are in a warmer climate.
The thermostat temp is the temp that it starts to open. That is it will only open a very small amount at that temp. It will generally take another 10 degrees for it to fully open.
p76rangie is offline
post #12 of 153 (permalink) Old 03-12-2017, 04:18 PM Thread Starter
Quoted: 61 Post(s)
Ooops. Trans cooler. Right.
Here's the tstat:
sobieski is offline
post #13 of 153 (permalink) Old 03-12-2017, 04:24 PM
Ian Matthews
p76rangie's Avatar
Quoted: 161 Post(s)
Two experiments in the one post. I could comment, but I won't.
As water does not retain the heat like glycol coolant, it will not get as hot as a glycol coolant. Yes, Glycol has a higher boiling point than water, but it needs this higher point as it will retain more heat. Most people will find a 5 to 10F drop in running temps when switch away from glycol coolant. By highlighting its only advantage, you are also highlighting its major disadvantage.
post #14 of 153 (permalink) Old 03-12-2017, 04:29 PM
Quoted: 290 Post(s)
Ian- How about not taking a giant, steaming shit on this thread and keep away from theoretical discussions and your various re-engineering theories. He just needs to walk through some basic diagnostic steps.
CT090 is offline
post #15 of 153 (permalink) Old 03-12-2017, 04:33 PM
Quoted: 290 Post(s)
Here's the tstat:
That's the OEM Rover stat. If that's what they actually sent you, then you got the best one.
Alot of these rover suppliers will label their pieces with the OEM numbers and then send you aftermarket parts. If you paid that much for it, it sure as hell ought to be OEM
CT090 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Towing reality Doug Myers Discovery Series II 4 08-04-2016 11:40 AM
Reality check? The Cisco Kid Defender 7 11-20-2010 04:25 AM
You may post new threads
You may post replies
