Old 04-04-2007, 08:01 PM   #1 (permalink)
He did what in his cup???
DevilDisco's Avatar
Default Throttle Body Cleaning
So Seafoaming is done. How do you clean the throttle body. I got a can of Gum Out, Carb & Choke cleaner. I read the can and it said not for EFI engines. Is there one that is safe to use.
Do I just take off the intake hose on the intake manifold and spray the cleaner in there and wipe it out or should I open the Butterfly and spray it in there as well?
'04 Discovery SE7. Last of the best.
DevilDisco is offline   Reply With Quote
Old 04-04-2007, 08:18 PM   #2 (permalink)
Mean and Green
Just spray it in there like you said, being careful not to get any on your MAF of course, and wipe it out. If you can get your rag in past your butterfly it wouldn't hurt to clean there as well. The carb and choke cleaner (as long as it is the O2 sensor safe variety) won't hurt anything if you spray it past the butterfly.
werldcup is offline   Reply With Quote
Old 04-05-2007, 07:58 AM   #3 (permalink)
DevilDisco's Avatar
Ok, I'll give it a shot this evening. I don't recall the can saying anything about O2 sensors. Should I take it back that specifically says 02 sensor safe?
Old 04-05-2007, 08:05 AM   #4 (permalink)
Mean and Green
I can't really say one way or another... The cleaner I bought said it but it may just be a marketing ploy.
Old 04-05-2007, 08:37 AM   #5 (permalink)
If you have an old tooth brush, after you remove the air intake hose, spray the inside of the t/body real well, also open the throttle plate and spray as fat down the throat as you can, then scrub out all the old build up, wipe out the excess with a couple pieces of paper towel.
Before you put it back together spray some of the carb cleaner up into the idle control by pass hose. Then reattach the hose, start the engine, do not pump the throttle if the engine is flooded, just let it crank till it starts then rev it up once and you are done.
Old 04-05-2007, 05:34 PM   #6 (permalink)
DevilDisco's Avatar
Which one is the idle control bypass hose. Still Learning
Old 04-05-2007, 06:54 PM   #7 (permalink)
What year is your truck?
Old 04-06-2007, 07:08 AM   #8 (permalink)
DevilDisco's Avatar
It's an '04 SE7.
Unrelated question. When I Seafoamed the nipple that I used on the intake manifold had a line attached to it...Wha is is for???
