Old 05-19-2008, 04:01 PM   #1 (permalink)
brian4d's Avatar
Default tick tick and away! (Alternator?)
Have a small concern, I've read the other (ticking) post but still don't know what to make of this. My 02 Series II with 73,000 is ticking while idleing. It ticks while the engine is hot and cold. When she's idleing it sounds like the ticking is coming from the alternator, I can put my finger on the top of the alternator and feel a viberation every tick. When I give it gas the ticking goes faster as well. 30 days and my LR warrenty is up, I would like to get this worked out before then. I'm also about to take a 300 mile trip this weekend, should I? I know this post is out there (many times) but nothing ever was mentioned about the alternator which is orginal. Any help is much appreciated, BTW oil change every 3,000 miles with Havoline 10W-30 Havoline oil filter she's full now. I put a can of sea foam in the gas tank today. I've had the 60,000 mile service where they (should) treat the engine. Sea Foam whatever. Thanks!
brian4d is online now   Reply With Quote
Old 05-19-2008, 05:24 PM   #2 (permalink)
gragravar's Avatar
see my other post (in the other ticking thread) about fuel injector pulse. not sure if you'd feel that at the alternator, but maybe on the injector top.
current rides:
2004 Land Rover Discovery II SE7 (still stock)
1992 Range Rover Classic (work in Progress)
2003 Audi allroad (more than a little modified)
1999 BMW R1100S
2001 BMW 330i (wife needed something to drive)
gragravar is offline   Reply With Quote
Old 05-19-2008, 07:29 PM   #3 (permalink)
polar's Avatar
I found out my Alternator has a bad bearing and makes this howling noise. (Rover part =675.00 US dollars)
Not really a tick but bad bearings cause a tick.
2002 Discovery 4.0 55K
Delo 400 5W-40 synthetic
CI-4 PLUS, CI-4, CH-4, SL (SAE 5W-40)
Zinc=1310
Phosphorus=1560
polar is offline   Reply With Quote
Old 05-21-2008, 10:06 PM   #4 (permalink)
I posted about my 02 Disco having the lifter tick. I'm going to check that exhaust gasket next just to see what happens as it will be a cheap trial. I'll let you know what I find out but I can assure you if you have a noticeable "tick" sound it's not your alternator or injector pilse.......
matz445 is offline   Reply With Quote
