Old 06-29-2008, 01:22 PM   #1 (permalink)
Jake
Question Tick...tick...pause...tick...tickish...
I have 2002 disco II with 54k...she has the tick (passenger side.) My mechanic did the following: flushed system, replaced lifters,replaced rocker arm(?) pulled out engine (twice) to bore out two cylinders and replace two pistons...plus whatever else...in the end, it came down to the "slipped sleeve you need a new engine diagnosis." He couldn't remove the tick so only charged me a mere $800 for the machinist fee. I've read some of Disco Mike and Steph's posts suggesting exaust gaskets and such...my question is...(drum roll) the "tick-tick" comes and goes, it's not constant. If I hit the accelerater the sound disappears. Then it may start again "tick-tick-pause-pause-tickish-tick-pause." She doesn't run hot or lose any power. And I certainly won't replace this 54k engine unless it blows up!
kazakdog is offline   Reply With Quote
Old 06-29-2008, 02:46 PM   #2 (permalink)
I believe you have an fool for a mechanic, you don't bore our Rover cylinder for a ticking sound.
Probably safe to say that because of his work, your engine is junk and no more money should be put into it.
Old 06-29-2008, 05:33 PM   #3 (permalink)
Jake
My bad, I'm no mechanic. Reading the invoice I see: replace lifters $1435, remove head and check guides $800, replace #6 and #8 piston/rod assy. $680...in addition to numerous gaskets, clamps and bolts. Nowhere the word "bore" indicated on this invoice.
In any case, the ticking still exists. Sometimes...sometimes not...no power loss (that I notice) or over heating.
Tick...tick...pause...tick...tickish... kazakdog New Member Introductions 0 06-28-2008 01:00 AM
