Old 04-13-2008, 04:31 PM   #1 (permalink)
3800 Tech
Street Wolf's Avatar
Exclamation Ticking/Clicking/Popping Noise While Turning Under Power
Just the other day I noticed that if I'm turning sharpe, and doing so while accelerating that I can hear a ticking/clicking/popping noise coming from the front end of the Disco.
But it only does it when I'm giving it gas and turning sharpe. If I let off of the throttle and turn sharpe there is no noise. Any ideas? Maybe a half-shaft (axle)?
Street Wolf is offline   Reply With Quote
Old 04-14-2008, 12:22 AM   #2 (permalink)
garywinter's Avatar
Hi there.
I have the same problem with my Disco. It is probably the CV joints.
I put a post in lasty week about CV Joints. Have a look there.
99 Discovery 2 XS V8
garywinter is offline   Reply With Quote
Old 04-14-2008, 07:38 AM   #3 (permalink)
Which way do you turn to make the noise?
I agree it is a CV joint and you shouldn't be driving it if you don't want alot of additional expenses.
Also check and make sure your front drive shaft has already had the replacement u-joints with grease fittings installed.
Noise when it's turning to the right. ObraViva Range Rover Classic 3 06-02-2007 05:01 PM
Noise from Disco II 2000discoII Discovery Series II 9 02-11-2006 05:12 PM
Dashboard noise (rattle) dieter Discovery Series II 0 01-18-2006 05:09 AM
HELP !! Strange Noise stevenjamesdavies Range Rover P38, Mk III and Range Rover Sport 4 12-08-2005 03:14 AM
2002 Disco TD5 "suspect" noise in Power Steering Robbo Discovery Series II 1 06-19-2005 03:11 AM
