Ticking Noise! Help!!! - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 13 (permalink) Old 08-03-2009, 07:50 PM Thread Starter
Quoted: 0 Post(s)
So I got a really good deal on an 04 disco because it had a ticking noise in the engine. I tried fixing it myself and did the following:
Replaced Rocking assembly
Replaced Lifters/Tappets
Replaced Rods
Replaced Spark Plugs
When I removed one of the valve covers I noticed a small lose round piece of metal, but I have no idea what it belonged to.
The ticking noise is still there! It seems to be coming from the passenger side.
I've also got the 5 following OBD2 Errors:
P0308: Cylinder 8 Misfire Detected
P1319: Misfire with Low/Empty FuelDrive cycle c: signal out of maximum range - above maximum
P0130: 02 Circuit (Bank 1, Sensor 1)
P0171: System Too Lean (Bank 1)
P1171: System Too lean, Bank A & Bank B
Help?!?!
Thanks!
locke547 is offline
post #2 of 13 (permalink) Old 08-03-2009, 07:54 PM
got mud?
Jupiter Rover's Avatar
Quoted: 0 Post(s)
Off Topic. Have you read Ender's Game?
Pete
2003 DII CDL equipped
33" Destination M/Ts
Jupiter Rover is offline
post #3 of 13 (permalink) Old 08-04-2009, 04:19 AM
Administrator
Quoted: 5 Post(s)
How many miles on the engine, I would start with an engine flush, 6 quarts of ATF, then do a oil pressure test, cold at idle and at 2000 RPM's then warm at idle and at 2000 RPM's and get back to us with the numbers.
Are you running a paper or K&N air filter and what weight oil?
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #4 of 13 (permalink) Old 08-04-2009, 07:17 AM Thread Starter
Quoted: 0 Post(s)
I'll answer the questions I can; the vehicle isn't with me right now.
60k miles
5w40 synthetic
locke547 is offline
post #5 of 13 (permalink) Old 08-04-2009, 07:31 AM Thread Starter
Quoted: 0 Post(s)
Also, it's ticking at the rate of approximatley 5 knocks a second and this increases with RPM. There also seems to be a diesel sound coming from the cylinder 8 area.
locke547 is offline
post #6 of 13 (permalink) Old 08-04-2009, 05:55 PM Thread Starter
Quoted: 0 Post(s)
So a few updates.. Haven't pressure checked yet...
The tapping noise is definitely coming from the 8th cylinder area
I think the engine might be loosing coolant
The engine intermittenly will produce steam from the 8th cylinder area - Coolant?
There is liquid dripping out of the exhaust - coolant?
locke547 is offline
post #7 of 13 (permalink) Old 08-05-2009, 12:29 AM
Topherhales
Quoted: 0 Post(s)
Hey ya, jupiter, i read that book a few years back. very interesting, right. Loved it. You like? Very random post tho! haha
Topherhales is offline
post #8 of 13 (permalink) Old 08-05-2009, 05:09 AM
lipadj46's Avatar
Quoted: 0 Post(s)
Get it pressure tested but it sounds like its time for a headgasket job as that's where coolant usually leaks from. Combustion produces water so that could be coming out your exhaust so smell it. Keep an eye on your coolant level in the mean time.
2002 DII 114,000 miles
lipadj46 is offline
post #9 of 13 (permalink) Old 08-22-2010, 05:46 AM
Quoted: 0 Post(s)
Drop your oil pan and look for a slipped cylinder sleeve. I have a 04 Disco II along with many others that are being told they need new motors$$$$. Some motors have defective cylinder sleeves and Land Rover has dodged this defect under warranty. If this is the case for your motor please call NHSTA @888-327-4236 and report this defect. Your motor could fail while trying to cross an intersection with on coming traffic.
2004ticker is offline
post #10 of 13 (permalink) Old 08-22-2010, 07:52 AM
Optimusduff's Avatar
Quoted: 2 Post(s)
Garage
I had to read Enders Game for a first year English course, I liked it;
2000 DII, 04 DII CDL lever. T-Top Liners, 2" Lift, Factory Winch Tray
Optimusduff is offline
post #11 of 13 (permalink) Old 05-28-2017, 03:34 PM
surveyorjames2000's Avatar
Quoted: 0 Post(s)
The timing chain tensioners?
surveyorjames2000 is offline
post #12 of 13 (permalink) Old 05-28-2017, 04:56 PM
tyl604's Avatar
Quoted: 55 Post(s)
Did you notice that this is a seven year old thread?
tyl604 is offline
post #13 of 13 (permalink) Old 05-28-2017, 07:43 PM
Special Agent
redtruck12's Avatar
Quoted: 121 Post(s)
Garage
7 years dead
And
D2 don't have chain tensioners !!
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
02 Ticking Noise MORENOG Freelander / LR2 7 05-23-2013 09:42 AM
Ticking (Tone?) noise under hood... MARGRETTE Discovery Series II 14 04-25-2009 10:49 AM
Ticking Noise Resolved! helievacpilot Discovery Series II 1 09-24-2007 07:04 PM
Disco II engine ticking noise at startup jedi Discovery Series II 21 09-19-2007 04:58 AM
Disco II ticking noise. GroverGreenRover Discovery Series II 20 05-26-2007 06:23 AM
You may post new threads
You may post replies
