Old 03-21-2007, 12:25 PM   #1 (permalink)
mowthat's Avatar
Default tires or lift
Here is my situation. I want tires and a lift for my 2000 disco II. I have the 255/65/16 with decent tread left and stock ride height. I want to go to 265/75/16 with a more aggresive tread. And I also want to lift 2" all the way around. What are your opinions on which should come first? Or perhaps buy the lift and finanace tires? How much larger are the 265's opposed to the 255's? Thanks
Jake
mowthat is offline   Reply With Quote
Old 03-21-2007, 01:49 PM   #2 (permalink)
Choqiees's Avatar
save till you can get both of them. one without the other is just awkward.
2002 Discovery II SE
1999 Range Rover P38 HSE
Old 03-21-2007, 06:14 PM   #3 (permalink)
Roverhound's Avatar
I would say go for the lift. The tires can follow. At least this way you'll be ready for tires.
It just doesn't matter.
Old 03-21-2007, 07:38 PM   #4 (permalink)
Steph's Avatar
Already answered you on discoweb.
Steph is offline   Reply With Quote
Old 03-23-2007, 07:00 AM   #5 (permalink)
'99 Disco II
wimp's Avatar
Default lift first
Tire rack can tell you the overall diameter of almost any tire of any sizse
select the tire and choose specs....
get the lift first if you must get one without the other.
both is obviously best
If I was going to to it again, I would get the RTE 2" lift although I love my OME lift. RTE is supposedly a bit higher
higher is better!
'99 Disco II
ACE / 2" OME lift
245 75 R16 Greatyear MT/R's
wimp is offline   Reply With Quote
Old 03-23-2007, 03:49 PM   #6 (permalink)
mowthat's Avatar
higher is better!
With the RTE 2" lift, if it is higher do you have to do the brake lines and abs lines?
Old 03-23-2007, 05:00 PM   #7 (permalink)
Roverhound's Avatar
No.
