Old 04-24-2006, 08:18 AM   #1 (permalink)
Question Top 5 breakdown causes???
I recently had a breakdown on my 2002 Disco with only 40 000km on the clock. Transmission oil leaked from fluid feed pipe where it connects to the transmission box.
I wondered what the top 5 causes for breakdowns on the Disco 2's were. What can one do maintenance wise to prevent breakdowns and/or damage? Are there specific known issues that one should look out for?
dieter is offline   Reply With Quote
Old 04-24-2006, 08:44 AM   #2 (permalink)
For me, the top five have been:
1-Coolant leak (valley pan gasket, factory defect)
2-ABS light trio (brake dust from crappy brake pads)
3-Drive belt tensioner (50k self destruct item, I'm expecting the fan-clutch to go soon)
4-Rotoflex (failure due to suspension lift and offroading)
5-Double Cardon joint on front driveshaft ( I didn't have any problems with it, but I rebuilt it anyways to prevent a very costly repair if it did fail. They have been known to break, causing damage to the engine and transmission)
The only real dissapointment I have with the maintenance record is the valley pan gasket. IMO-It is an unacceptable factory defect that Land Rover should fess up to and fix for free. The rest of these problems I can live with
O.B. is offline   Reply With Quote
Old 04-24-2006, 10:36 AM   #3 (permalink)
I pretty much agree with O.B.
If you were looking to use the truck as a serious weekend wheeler then I would add weak diffs.
Under coolant issues, I would add head gaskets.
But, I wouldn't drive any other vehicle.
Old 04-24-2006, 01:37 PM   #4 (permalink)
Otherwise known as STEVE
spark plug wires. My own Disco was stricken at 28K and went into limp mode with flashing MIL. I've seen several others do the same.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 04-24-2006, 04:08 PM   #5 (permalink)
1) operator error
2) operator error
3) operator error
4) operator error
5) what those guys said
stb616 is offline   Reply With Quote
