3800 Tech
Recently my 2000 Disco has been having a shuddering problem when shifting from first to second gear. Sometimes it revs up a little higher than it should and when it shifts it will shudder. Sometime much more violently than other times.
I already drained all of the tranny fluid and but new stuff in hoping that maybe it was just low on fluid or something, but no luck there. It also threw a OBD code that stated '4th gear incorrect gear ratio'. However the only time I see a problem is when shifting from first to second. After that every other gear shifts just fine. |
#5 (permalink) | |
3800 Tech
My SES light is on but it was just the '4th Gear Incorrect Gear Ratio' and bad O2 sensor along with the MAF showing up bad. |
2002 Discovery II SE
You usually have to fill it twice. Once while its not running, then start it and fill it again.
If the truck isnt running when you check it, its the incorrect level. The truck has to be running. Im not saying you didnt do it right. Im just adding that for other folks that might come along and find this thread with transmission doubts. ![]() |
#7 (permalink) | |
3800 Tech
Yep, checked it twice while it was still running. This problem was occurring before I ever drained and re-filled the tranny though. I was just hoping the fluid was old, and low. That however, and unfortunately, was'nt the case since I still have the problem. |
#10 (permalink) |
thats because the incorrect numbers being supplied by the maf tell the comp that is probably running lean so it changes shift points so you get the hesitation.
Completely normal on all obd2 vehicles;
| Thread Tools | |
| Display Modes | |
| 97 disco tranny issue | dirkmc3 | Discovery Series I | 7 | 10-07-2008 02:53 AM |
| Wierd Range Rover Classic Problem | NikeCheck246 | Range Rover Classic | 5 | 03-06-2008 11:56 AM |
| rr v8 4.4 nikasil problem???? please help. | 2002hse | General Land Rover Discussion | 4 | 10-19-2005 02:00 PM |
| rr v8 4.4 nikasil problem???? please help. | 2002hse | Range Rover P38, Mk III and Range Rover Sport | 2 | 10-12-2005 09:11 AM |
| Intermittent Driveline Vibration at 60MPH | AdrianL | Range Rover Classic | 10 | 06-24-2005 08:52 AM |
