Has anyone installed a aux. transmission cooler? I'm wondering what a good one to buy would be and if there any install issues I'll run into.
Thanks oh, on that note what trans fluid is best to use? Can I switch to a full synthetic like merc V? |
Why do you feel you need an aux. cooler, are you doing any trailor hauling?
As for the coolant, there are synthetic fluids out there that can be used in place of Dextron, Royal purple is doing alot of advertising lately on the fluid. Just remember to get all the fluid out, you have to empty the torque convertor which means doing a complete flush and most shops don't have the adapter needed to do a Rover. Mike |
I hadn't thought about any adapters for a flush, good point.
Heat is number one reason for fluid breakdown, less heat = less breakdown. I do tow at times not all the time, but enough I suppose. I Know you can get a decent cooler for about $75 but I don't know the fitting size in a disco and haven't had any luck finding a cooler so far. |
Actually we use BG transmission service. Solves both problems at once.
on a 60k service since you just drop the plug and refill we decided to go with BG instead. Basically you end up changing all the fluid instead of a few qts. And also its cleaner and faster. All you do is hook into the line at the radiator and hook the BG transmission machine in line and with the line pressure of 60psi the truck does all the work in less then twenty minutes flat. Its that easy. You see with a low line pressure like in a few trannies made for Ford and Jag they have a line pressure of ten psi. Not good if you want to change the fluid quickly. It can take almost an hour to change. You need to pump the RPMs to get it go a bit quicker. But with an additional pump on newer BG machines it still isnt that fast. Also too we add protectant in the fluid. Works great for seals and other stuff. Solves torque shudder in Fords by leaps and bounds. They do have cleaner with the package but we only put the stuff in if there is a dipstick. Thats what we did with Fords too. If no dipstick then just swap the fluid and add the protectant. If it was a regular 30k it wasnt as bad. If the fluid was black it was a tossup and usually we hunkered down and put it in the tranny even though it was a pain. By the way the fluid for a LR3 costs fifty bucks a quart and takes sixteen. Not cheap by any means. |
