Transfer Case oil change - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 9 (permalink) Old 09-06-2008, 10:30 AM Thread Starter
Britabroad
Britabroad's Avatar
Quoted: 0 Post(s)
Hi all - 2000 DII SD7 - have the Mobil 1 75w90 for a fluid change and the rave manual - but what size / type of socket do I need for the fill plug as I can't even see it ??? also Rave says Loctite the fill and drain plugs - is that the best ??? thanks.
Britabroad is offline
post #2 of 9 (permalink) Old 09-06-2008, 11:32 AM
Administrator
Quoted: 5 Post(s)
Use a extension from a 1/2" socket and ratchet, will fit right in.
Don't forget to do your diffs. also, 2.4 quarts for the t/case and 1.8 for each diff.
Also make sure to check the magnetic plus for metal chunks.
Disco Mike is offline
post #3 of 9 (permalink) Old 09-06-2008, 03:55 PM Thread Starter
Britabroad
Britabroad's Avatar
Quoted: 0 Post(s)
No metal chunks - a few tiny shavings. Drain plug was flush with the casting / came out and went in fine. Fill plug was sticking out 3 to 4mm - went back in the same - torque wrench suggested not going any tighter - anything to be concerned about ?
post #4 of 9 (permalink) Old 09-07-2008, 05:36 AM
Administrator
Quoted: 5 Post(s)
As longf as you are not leaking. If you are leaking, try some teflon tape and a little more torque.
post #5 of 9 (permalink) Old 09-07-2008, 09:13 AM
2002 Discovery II SE
Alak's Avatar
Quoted: 1 Post(s)
Anyone know where I can get replacment fill plugs for the diff's that are NOT plastic?
Mine are starting to get a little worn.
2002 Discovery Series II SE. CDL. OME Suspension. 265/65R18 BF Goodrich All-Terrain. ARB with XD9000i
Alak is offline
post #6 of 9 (permalink) Old 09-07-2008, 09:39 AM
Administrator
Quoted: 5 Post(s)
Expedition Exchange, they have solid brass plugs with o-rings.
post #7 of 9 (permalink) Old 09-07-2008, 01:32 PM
Alak's Avatar
Quoted: 1 Post(s)
Thanks Mike! Looks like they have a couple other things I'd like to aquire as well.
Alak is offline
post #8 of 9 (permalink) Old 02-01-2009, 09:44 AM
Endangered Appalachian Mountian Squid
parsonsjunior's Avatar
Quoted: 0 Post(s)
Should I run some kind of flush or solvent thru the diffs or t-case prior to draining. There is quiet possibly mud or water in the diffs from my last outing...
Bigamy is having one wife too many. Monogamy is the same.
Oscar Wilde
parsonsjunior is offline
post #9 of 9 (permalink) Old 02-01-2009, 10:58 AM
Administrator
Quoted: 5 Post(s)
No, just drain and inspect the magnetic drain plug fefore refilling. A little magnetic mud is normal, if though you see checks of metal or shinning bearing material, then you might want to go to the heavier 85W/140 gear oil to prolong the t/cases life, same for both of the diffs.
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
A rookie attempts to change transfer case chain skipbrakes Range Rover P38, Mk III and Range Rover Sport 1 09-02-2008 07:18 PM
Driveshafts & Transfer Case Output Flange / Bearing murray.richardt Discovery Series II 2 09-02-2008 08:18 AM
Changing out a transfer case on a 1995 Disco D1 texaninmass Discovery Series I 0 04-14-2008 05:12 AM
Diff Lock/Follow-up to transfer case removal helievacpilot Discovery Series II 2 03-28-2007 07:55 AM
Renewing fluids in differential, transfer case, swivel housings glenncof Range Rover Classic 2 03-05-2007 10:37 AM
You may post new threads
You may post replies
