transmission not engaging - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
View Poll Results: trans problem
not engaging in drive 1 50.00%
not engaging in reverse 1 50.00%
Voters: 2. You may not vote on this poll
Old 01-29-2013, 08:24 AM   #1 (permalink)
Default transmission not engaging
the other day on mt hood my disco was running great then went to turn around and heard a clunk at 1 male an hour felt like it slipped into neutral then all auto trans positoins like its in nutral it will go in to park but clicks for a few secounds ive tried every thing all different positions still nothing had to get a flat bed tow almost 100 miles . any ideas on where i should start.
when in drive front drive line spins but not the rear same with reverse.
tony41-2003disco is offline   Reply With Quote
Old 01-29-2013, 08:53 AM   #2 (permalink)
Administrator
You have broken either your front diff or cv joint. How mechanical are you.
Might want to send me your number and I'll call and walk you thru what to do.
Need Parts?
paulgrant@mac.com or call 203-770-1699
willtillery@roverguy.com or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8, http://lucky8llc.com/
British Parts of Utah, http://www.bputah.com/
Old 01-29-2013, 09:28 AM   #3 (permalink)
i can do almost anything just dont know much about trannys. its at a friends at the moment 50 miles away but im triing to figure out what to look for first.ive been out of work for the past 3 years so doing the work myself is my only option 503-875-8116
Old 01-30-2013, 10:07 AM   #4 (permalink)
Keanan's Avatar
When you can, crawl under it and turn the front drive shaft by hand. If you broke an axle or CV then the front shaft should spin by hand.
What are we voting on?
Keanan is offline   Reply With Quote
Old 02-07-2013, 09:07 PM   #5 (permalink)
im going to check the things you have suggested in the morning i might call you disco mike for addvice and a plan of attact thanks again for all the help
Old 02-08-2013, 05:46 AM   #6 (permalink)
Administrator
Star your engine, put it in gear and watch both drive shafts to see which one is spinning. If you find one then you have a front or rear diff issue and yes, lets talk.
Need Parts?
Old 02-19-2013, 07:52 AM   #7 (permalink)
thanks disco mike your help and advise was right on the money.i still haven't down loaded the rave manual cuz i suck at computers but it only took me 3 1/2 hours to pull the front dif and put the new one in pease of cake it runs great .next project is a cdl t-case.
disco Mike knows discos THANKS
ABS/TC engaging under accelleration creeves223 Discovery Series II 2 04-10-2012 09:15 PM
1997 Discovery I - Park Not Engaging wtsheff Discovery Series I 0 10-16-2010 04:39 PM
engaging CDL fiach Discovery Series II 28 04-30-2009 11:36 PM
Not engaging gears! troverman Discovery Series II 4 12-14-2005 09:06 AM
Diff lock engaging Marcus General Land Rover Discussion 5 02-17-2005 01:38 PM
SEO by vBSEO 3.3.2
