Old 05-16-2008, 09:24 AM   #1 (permalink)
dzeyer's Avatar
Default Transmission Ticking/Claking (99 DII)
I've searched here and Discoweb for everything transmission related, but nothing seems to be correlating to my problem. I have a slight "ticking/clacking" coming from my transmission. It shifts just fine and drives great. I have it on start up and it will happen when idling. If I shift to Neutral, it goes away. I know it's not my drive-shafts since they aren't turning at startup, and I had my top end rebuilt a while ago, so It shouldn't be lifters etc. (the sound is coming from underneath). I've also replaced the tranny filter and gasket and did a complete flush with new fluid. So right now I'm just tryin to figure out what this could be. Thanks for any help.
-Aaron
99' DII with 108k miles
dzeyer is offline   Reply With Quote
Old 05-16-2008, 01:13 PM   #2 (permalink)
Just to mention, not good to flush a high mileage tranny, can clean things out too well causing problems.
As for you problem, how about a cracked flex plate?
1995 LWB Transmission shifting problem serge9444 Range Rover Classic 3 11-25-2007 11:26 PM
transmission problems scotth Discovery Series II 1 04-20-2007 10:06 AM
Transmission Service Kit AAXD Discovery Series I 7 11-17-2005 08:36 AM
Transmission or differential? OaklandRover Range Rover Classic 2 01-08-2005 01:47 PM
Discovery Transmission and Transfer Case 1996 Land Rover Discovery 4.0 Rangie Mark Land Rover Parts and Accessories 2 08-22-2004 06:57 PM
