» Sponsors
» Sponsors
Old 06-15-2009, 11:01 AM   #16 (permalink)
Rover Driver
tcpfl's Avatar
Originally Posted by Roverhound View Post
That you don't replace the steering damper to fix vibrations which is what you suggested in your first post.
Steering stabilizer systems are specifically engineered to improved handling characteristics and improve wheel vibration - which can lead to suspension component failure. Steering stabilizers are shocks that help absorb the jar and bump to your steering system. This action results in increased vehicle control under all driving conditions by reducing steering shimmy and driver fatigue. A stabilizer will also help improve tire wear and even provide better control in blowout conditions.
I don't know who pissed you off today but I'm not going to argue with you.
Tom
2006 LR3 SE - Stock except for 255/60/18 General AT2s
2004 Disco II SE - 3" OME HD Springs/Shocks, Borla Cat-Back Exhaust, My Front Shaft Is A Woody, ARB Sidesteps, 255/60/18 General AT2s
2001 Disco II SE - Sold
tcpfl is offline   Reply With Quote
Old 06-15-2009, 12:11 PM   #17 (permalink)
Roverhound's Avatar
Nobody pissed me off. I'm just saying that steering dampers aren't for curing vibrations. They are a mask at best.
Wherever the above quote is from it's only partially true.
You have to as yourself where the vibration is coming from and go from there.
It just doesn't matter.
It's not like I am going to do this without asking my mom first.
Old 06-15-2009, 12:39 PM   #18 (permalink)
Rover Driver
tcpfl's Avatar
Steering stabilizers are essentially a shock absorber for your steering system. They are highly recommended for all vehicles with over-sized tires, a winch or snow plow to increase control and handling. Stabilizers dampen out wheel shimmy and help prevent the steering wheel from being jerked out of your hands in rough terrain or when a road hazard is struck by the front wheels. A steering stabilizer is a proven safety device in the event of a blow out. Steering stabilizers are engineered to restrain "bump steer" and front end vibration, giving added life to tires, ball joints and other steering components. A lot of vehicles now come from the factory with a steering stabilizer.
steering stabilizers
Acting as a horizontal shock absorber, Magnum® steering stabilizers reduce vibrations that travel through the steering system to the driver.
Monroe Magnum® Steering Stabilizer
Have a nice day.
Tom
Old 06-15-2009, 01:06 PM   #19 (permalink)
Roverhound's Avatar
Have a nice day.
You're getting your information from a sales flyer?!!!
Old 06-15-2009, 01:28 PM   #20 (permalink)
Rover Driver
tcpfl's Avatar
And you've provided absolutely zero information... again I ask, what is the point of this???
Tom
Old 06-15-2009, 01:34 PM   #21 (permalink)
Beach Bum
brian4d's Avatar
Orange,
Take your Rover to a Discount tire and let them balance the tires. My experience is that 'most' people claim to balance your tires and don't. That's right they take your money and run. Look, have weights have been moved on the tire? I'd be willing to bet your 'balance' isn't up to par... Furthermore, 50 and 75 represent balance issue most likely.
Brian Morgan
Indecision may or may not be my problem. -Jimmy Buffett
2002 Discovery SE (Stock - No ACE, No SLS)
1995 Nissan Pathfinder SE (Sold)
1999 Chevrolet Cavalier (permanent loaner)
brian4d is offline   Reply With Quote
Old 06-15-2009, 01:45 PM   #22 (permalink)
Roverhound's Avatar
Simple.
Answer this. You have a car, it suddenly developes a shimmy, shake, vibration, whatever, in the steering. What are you going to do to fix it? Add a steering damper? Or would you fix the initial problem?
Old 06-15-2009, 01:57 PM   #23 (permalink)
Rover Driver
tcpfl's Avatar
orange2 said he has a shake (never a mention of vibration) and described what he's done to solve the problem.
I asked if he had replaced the steering damper.
If you take that simple exchange to mean I implied that a steering damper is the fix-all, end-all repair for all shakes, vibrations, shimmys or any other bump-in-the-night problem on a vehicle then you obviously read a WHOLE bunch more into what was said than what was meant.
Have you taken your medication yet today?
Tom
Old 06-15-2009, 04:53 PM   #24 (permalink)
Roverhound's Avatar
So now you're throwing out insults? Is that all you got?
That's pitiful.
Old 06-17-2009, 09:26 AM   #25 (permalink)
My Friend is the manager at discount. So I know it was done. It actually took a little of the shake out but it is still there. My cousins 99 is doing the same thing at the exact same speeds. If that helps
Aaron Jochim
00 Discovery II
74 914
orange2 is offline   Reply With Quote
Old 06-17-2009, 09:56 AM   #26 (permalink)
Rover Driver
tcpfl's Avatar
Maybe try Roadforce balancing your tires. They balance the wheel and tire as a unit and costs around $15.00 per wheel. I had some vibration on my LR3 at high speeds and this worked like a charm.
Here is the technical information:
Hunter GSP9700 Wheel Vibration Control System
You can find a shop in your area who has the machine here:
Tom
Old 06-17-2009, 10:01 AM   #27 (permalink)
Beach Bum
brian4d's Avatar
If it makes you feel better my steering wheel will viberate from 35-40mph and I'll get a loud harmonic HUM @ 75 and it goes away at 80. I've learned to live with it...
Brian Morgan
Old 06-17-2009, 10:02 AM   #28 (permalink)
You've probably already checked this, but mine will shake a little if the tire pressures are off - especially if the front tires arean't equal.
raoul76 is offline   Reply With Quote
Old 06-17-2009, 11:37 AM   #29 (permalink)
Over on DiscoWeb, a similar topic was started. A guy was getting a shake in the steering wheel at around 48mph. It was an '04 though. About 10 or 11 other people (including me) were all experiencing the same thing. But I haven't had any shake at 70+.
Here's a link: Slight wobble, 04 D2 - DiscoWeb Message Boards
White 2004 Discovery SE7
Safety Devices Rack, Genuine Ladder
Soon to be...
3" OME/RTE lift with some Super Swamper TSL Radials...
c0smo kram3r is offline   Reply With Quote
2000 Disco II Parts Truck. What to keep?? Riflman Discovery Series II 6 10-10-2008 07:19 PM
Floor restoration complete (truck bed coating) yieldsign2 Range Rover Classic 4 06-01-2008 05:01 PM
Bubba and his new truck 75series3 The Lounge 10 05-02-2008 05:48 AM
'95 RR Classic LWB EAS question suberec Range Rover Classic 11 11-23-2005 05:30 PM
WARNING: LONG POST - Another LR Embarrassing Moment... 01001010 Off Road 13 08-14-2005 11:23 AM
