I have a Discovery II 2004
In haynes worshop manual for the 12 months service it says to clean the fuel sedimenter which is attached to bottom of the fuel filter. On checking under the R/H side rear wheel arch, my discovery does not have one fitted. Could anyone tell me if this was deleted on my modle year or is it now included in the fuel filter. Thanks in Antisipation. |
The car is a TD5 Diesel
There is a fule filter fitted but it has a plastic piece on the bottom which I think Must be the fuel sedimenter. In the haynes book it shows the fuel filter with no plastic bit on the bottom but with a sedimenter screwed into the bottom which has then got an electrical block connecter pushed into the bottom of the sedimenter. To change the fule filter it says to unplug the electrical conection, unsrew the sedimenter, fit the sedimenter to the new filter then refit the filter and reconnect the electics. The only thing I can think is that this type of fuel filter with a plastic bit fitted to the bottom, which unscrews to drain has replaced the original setup. |
