#31 (permalink) | |
As for service places, that's another thing you have to be aware of if you replace them with greasable type. Since the DII doesn't come with greasable DC u-joints a service center might miss greasing them. If you don't do your own service it's important that you mention to them that your DC needs service as well.
Tom Rowe Atlanta, GA Four wheel drive allows you to get stuck in places even more inaccessible. 62 88 reg 67 NADA x2 74 Air Portable - The Antichrist (tag 6A666) 95 D1 - R380 95 D90 - R380 |
#32 (permalink) |
2002 Discovery II SE
Exactly. Its just another way you have to stay on top of truck maintenance. The last owner of my truck was dead lazy. When I changed the fluid in all three diffs, they were all black and goopy (never been changed) except for the back. The only reason the back was cleaned was because 40,000kms ago, the rear axle seals were done.
I have one greaseable joint on the front while the other two are sealed. Im not sure why, but It came what way. I imagine it failed at some point and way replaced that way. Im going to take the shaft out and get everything replaced, then balanced. Ever since I put the lift on, I get a bit of driveshaft shimmy from time to time. |
#33 (permalink) |
The DII front propshaft comes with the diff end greasable and the DC sealed.
#34 (permalink) | |||||||||||||||||||
Greaseable U-joints have been around for....well, for over 100 years in one-way-shape-or-form. Greasable U-joints are not new. Greasing your u-joints is common automobile maintenance. It's like changing your oil, rotating your tires, changing your filters, or replacing your brake pads. Quote:
If the "average Joe" is the Holiday weekend off-roader, that person probably understands the importance of greasing the u-joint. Quote:
Anyway, I call major bullshit here. I can count on one hand the number of times I've scraped my drive shaft. It's not really a common thing and I play in the rocks more then mud. In addition, the people I wheel with also play more in the rocks than the mud and do not have this problem. When your drive shaft meets a rock, typically, the drive shaft twists up like a pop can. If your drive shaft yokes are coming into contact with the ground, I think you'll have more problem than just a snapped off grease zirk. Quote:
Dumb.... Quote:
#36 (permalink) |
Ian Matthews
Everyone can look up Hank's posts and you will see that he only posts to attempt to have a go at me. 90% of what he states is just shit.
Most D2's will get 100,000 miles plus out of a prop shaft. A new one is not cheap, but not much more expensive than many long life components on your car. A prop shaft assembled in the factory with Uni joints can have better tolerances, etc, that one assembled in a mechanics workshop. Therefore such units offer better durability. Landrover list the top uni as a replaceable unit but not the double cardon. Unless you are anal with your maintenance and greasing unis, a sealed unit will most likely last you longer. Basic design of a greasable unit is that it has to allow the grease out past the seals when you grease it. Otherwise you will simply blow the seals out when you grease it. Why being designed to let grease out they are effectively designed to let mud and water in. They rely on you greasing them to get it back out again. A sealed unit is designed to keep the grease in the unit and therefore has better tolerances to keep water and mud out. It is only fools like Hank that feel the need to knock any changes to a vehicle as being the cause of failures. As stated previously I have seen many greasable units fail quicker than sealed units on D2. In regard to the damage they can cause, for some reason the transmission does not seem to notice whether it is a sealed or greasable unit that hits it. |
#37 (permalink) |
Good lord, Boob, where do you get this crap from? Do you just make it up as you go?
03 DII- S w/CDL, lifted, armored and beaten on- Beasley 90 RRC- stock and babied- Brutus Classicus |
#39 (permalink) |
Alright, Alright - - - Do we have any insurance adjusters that have access to their database. Insurance companies collect the most information about cars, trucks, boats whatever and collect reliability data from around the world. If some here works in the insurance industry and has access to this type of information we can put this thread to rest..... The truth be known, I see D1's and D2's driving around here all the time and they aren’t even members here or anywhere else for that matter, have they had U-joint issues??? The adjusters know!
#40 (permalink) |
Owner Since 98
I joined this forum at about 117k miles...i learned about this u joint problems then and at 128K I finally replaced them...to sealed ones. So i got 128K on the originals...that "60k borrowed time" didnt apply to me. That greasing shit every oil change "or sooner" is a waste of time for people with lives outside the garage. See: Family time.
Just my two cents. ![]()
If you don't lack sleep...you don't matter. |
#43 (permalink) |
Rebuilding Rover
Nope ad blocker plus 69 splines
with a mini spoolI just pumped the mud and crap from this weekend outta my uj's this afternoon gotta love greaseable uj's. ![]()
"If you can't stand behind our soliders, then by all means stand in front of them." unknown quote. "Only two defining forces ever offered to die for you, Jesus Christ and the American G.I. One died for your soul, the other for your freedom." http://www.wheelinrovers.com/ 91 Range Rover Classic 90 RRC Parts truck 94 Saab gas mileage beater
#44 (permalink) | |
Ian Matthews
I have not said that greasable units are no good, just maybe not the best option for most people. Even if you say that greasable units will last 20% longer than sealed units (even though there is no evidence of this) you might save $10 every 7 to 8 years by having greasable unis. To save this you have to get underneath every month or so and grease the suckers. Over that 7 to 8years you will spend over $20 in grease and there is the cost of the grease gun, etc. It would appear that some people just have nothing better to do. I notice that the usual knockers are here again. Never have anything to contribute except attempting to knock what someone else says. They get pretty good at this as they managed to knock what you say without actually listing an opinion of their own or being specific about what they reckon you said was wrong. Seeing this is the D2 section we can actually have a survey as to how long the drive shafts last. So far we have a couple that lasted more than 100,000 miles, none that have lasted less than 60,000 miles. So lets hear from those that have replaced them or those that have more than 60,000 miles on the clock and have not replaced them. Lets deal in facts rather than stupid comments from fools. |
#45 (permalink) | |
Well, I searched for all of 10-seconds and found this. I'm sure I could find many more if I felt the need to actually look. I'm sure others will chime in.
Broken drive shaft - DiscoWeb Message Boards What you fail to understand, Ian, if that it's not only grit and grime that kills the u-joints. The Double Cardon shaft sits directly between two catalytic converters which gets very hot. These converters 'basically' boil the grease. Boiled grease, or even grease thats seen high temps, is not worth a shit - often referred to as burnt grease. I guess one thing that's not common knowledge is if it's the actual u-joint that causes shaft failure on the D2. It very well could be the center kit going bad and placing additional stress on the u-joints. We may never know, really. That's why it only makes sense to get under your truck every-so-often and grease the joints. I have a D2 shaft in my D1 and I even take a syringe and grease the center kit. It's just common sense stuff. It takes 2-minutes to do the front and rear shaft. For the morons who do not service their own vehicle, if the mechanic does not see a grease zirk on the drive shaft, that drive shaft is probably going to get zero attention. But, if there is a grease zirk and you have a halfassed mechanic, your u-joints may (should) get greased. That's only going to add addition life to your drive shaft. Quote:
| Thread Tools | |
| Display Modes | |
| CV Joint replacement info Please! | Denver Dan | Range Rover Classic | 10 | 03-04-2007 08:30 PM |
| [D2] CV Joint Trail Fix | rmuller | Tech & DIY | 0 | 01-03-2007 02:53 PM |
| CV joint woes...replacement and other things! | Mark HH | Discovery Series I | 1 | 06-17-2006 10:28 PM |
| DII CV Joint Field Repair | SCSL | Off Road | 1 | 05-30-2006 09:50 PM |
| U-joint | roverX | Discovery Series I | 2 | 03-22-2006 03:54 PM |
