Hey everybody!
Well, tons of new parts recently put in, but I still have a small vibration. I know this might be normal, but I haven't touched any of the U joints yet. I have 120,000 on it. Year 2000. I noticed when going down the road, it has a very slight vibration, and if you go down a hill, it gets louder and more obvious. I just had new tires put on and balanced, but it did this before also. Any advice? I can't remember proper procedure for checking U joints so I thought I would ask everybody's help. Thanks alot for any suggestions!
Scott
Oh, and I just put a new drag link assembly, track rod assembly, steering damper, Bilstein shocks all the way around, and then the new tires and balancing. I've only had it since 104,000 miles, and I read in a few places they should have been changed by now anyways. thanks again
Do not take a chance with the front drive shaft. If it breaks it willcause massive distruction to the engine gearbox and transfer case. Replace all the U-Joins front and back and also replace the rubber coupling on the rear prop shaft.
99 Discovery 2 XS V8
Coils Replaced Air Bags
Mod on Front Bumper
Dastek Unichip
BFG All-Terrain Tyres
So what else have you failed to service? Doing thing like this will cost you dearly in the long run.
Now since you didn't lube the u-joints before, replace them all. as already mentioned, including the centering ball and rotoflex, then grease the u-joint at least every other oil change.
When in doubt,,, rip em out...all indicators say it's time.
U Joints - Advance Auto - Neapco / PDQ 1-0005 @ $13.95
Centering Ball kit - Advance Auto - Neapco 7-008ING ??$$
Thanks for the local sources DiscoD2. I appreciate it, thought I would have to do some searching. I'm learning as I go....totally novice but hope to catch on with everything. Thanks again
Thanks Mike. I'm trying to get a handle on all the maintenance and time frames for maintenance, and I appreciate your help.
I just had a new oe front drive shaft installed ($750). All vibrations gone. Sweet investment.
If it's really OEM plan to do it again at a maximum of another 50k miles. Most will last that long, though some have failed quite a bit sooner.
IMO installing an OEM propshaft is a complete waste of money unless your first one was beyond repair and you needed a propshaft ASAP to get you by for a few months until you have the time to rebuild it with greaseable u-joints.
Normally it wouldn't be worth it at all since you can get a new heavy duty Tom Woods or Great Basin propshaft for about 1/2 the amount, but would take you a day or two to get.
Tom Rowe
Atlanta, GA
$750 for a front shaft, boy they got you.
Should have done a little reading and paid $348 for a new Tom Woods shaft and 15 minutes of labor.
Tom, my first one failed at 37,000 miles, course I was wheeling just about every weekend.
