» Sponsors
» Sponsors
Old 01-05-2009, 09:40 PM   #1 (permalink)
1999 Disco II "The Rhino' 179,000 miles and going
SafariDave's Avatar
Default Using the Homelink on Disco II 1999
Since our Disco II has gotten vandalized twice by our nice neighborhood Polish kids. This is not counting when they vandalized twice our RRC. We have decided to park it in a garage. I am trying to program the Homelink garage door opener has anyone had luck with it? I tried without success today. So I am still using the remote opener they gave me. But I rather use the Homelink that comes with the Rover.
Thanks, Dave
The City is a Jungle.
1999 LR Disco II SD The Rhino
1991 RRC (Sold) We will miss the Turtle
1988 RRC (sold)
SafariDave is offline   Reply With Quote
Old 01-05-2009, 09:55 PM   #2 (permalink)
The Zebra
LandyII's Avatar
Gallery: 17
Thanks, Dave
Here is a complete homelink programming guide:
Here goes a long c/c/p
If you have any problem programming it, call LR Free Tech Support: 1-800-355-3515
If you have previously programmed your
HomeLink® Transmitter, proceed to step
2. Otherwise, hold down the two outside
buttons on the HomeLink® Transmitter
until the amber light begins to flash.
Release both buttons.
2. Decide which one of the three channels
you want to program.
3. Hold the end of your hand-held transmitter
against the HomeLink® Transmitter
(underside of the mirror) so that you can
still see the amber light (see illustration).
4. Using both hands, push the hand-held
transmitter button and the desired button
on the HomeLink® Transmitter. Continue
to press both buttons through step 5.
5. Hold down both buttons until you see the
amber light on the Land Rover HomeLink®
Transmitter flash, first slowly and then
rapidly. It indicates that you have
successfully programmed the HomeLink®
Transmitter to learn the new frequency
signal. Release both buttons once the
rapid flashing begins
Operating HomeLink:
Operating the Land Rover HomeLink®
Transmitter
Once it is programmed, the HomeLink®
Transmitter can be used in place of your
hand-held transmitter(s). To operate, simply
press the appropriate button on the HomeLink®
Transmitter. The amber light comes on while
the signal is being transmitted.
NOTE: If your hand-held transmitter appears to
program the HomeLink® Transmitter, but does
not open your garage door and, if your garage
door was manufactured after 1995, your garage
door opener may have a ‘code protected’ or
‘rolling code’ feature.
A ‘rolling code’ type of system will change the
‘code’ of your garage door opener every time
you open or close your garage door.
To determine if you have one of these systems,
depress the button on your HomeLink®
Transmitter that you programmed. If the amber
light on the HomeLink® Transmitter flashes
rapidly for 1-2 seconds, then turns solid, your
garage door opener has a rolling code system.
Training a garage door opener equipped with
‘rolling codes’
To train your ’rolling code’ garage door opener
to operate from your HomeLink® Transmitter,
follow these steps:
1. Program your hand-held transmitter to the
HomeLink® Transmitter by following the
procedures outlined in ‘Programming’,
page 97 (if you already completed this
programming, proceed to the next
instruction).
2. Train your garage door opener receiver to
recognize your HomeLink® Transmitter:
(your garage door opener receiver will
learn to recognize the HomeLink®
Transmitter by following the same
process used to train the hand-held
transmitter)
a) Remove the cover panel from your
garage door opener receiver (the receiver
should be located by the garage door
motor).
b) Locate the training button on the garage
door opener receiver. The exact location
and colour of the button may vary by
garage door opener brand. If you have
difficulty locating the training button,
reference your garage door opener
manual, or call 1-800-355-35215.
c) Press the training button on the garage
door opener receiver for 1-2 seconds.
d) Return to the HomeLink® Transmitter
in the vehicle and depress the
programmed HomeLink® Transmitter
button for the duration of the rapid flash of
the HomeLink®’ amber light, (1-2
seconds). Release the button and depress
the button to confirm that the HomeLink®
Transmitter has been trained to the
receiver.
e) Your garage door opener should now
recognize your HomeLink® Transmitter.
You may use either your HomeLink®
Transmitter or your original hand-held
transmitter to open your garage door.
If after following these suggestions you still
have difficulties programming your HomeLink®
Transmitter, call toll-free for customer
assistance: 1-800-355-3515
Erasing channels
To erase all three programmed channels, hold
down the two outside buttons until the amber
light begins to flash, then release both buttons.
Individual channels cannot be erased, but can
be reprogrammed using the procedures for
programming the HomeLink® Transmitter
(steps 2 through 5).
NOTE: Be sure to retain your original
transmitter for future programming procedures
(i.e. new vehicle purchase).
When selling your vehicle, be sure to erase all
channels on the HomeLink® Transmitter that
you programmed.
Accessories
Accessories for your HomeLink® Transmitter
are available from the manufacturer of the
device. If you would like additional information
or would like to purchase other accessories
such as home lighting or security products that
can be operated by the HomeLink® Transmitter,
please call the toll-free: 1-800-355-3515.
Hope this helps ;-)
Landy II
Taken off of page 100 of the RAVE CD
My Ride - 2002 Discovery II - Stock And Going To Stay That Way
LandyII is offline   Reply With Quote
Old 01-05-2009, 10:02 PM   #3 (permalink)
SafariDave's Avatar
Wow Landy thanks again
I will try it out tomorrow. By the way how is your Disco doing?
David.
1988 RRC (sold)
Old 01-05-2009, 10:02 PM   #4 (permalink)
Deployed OIF
ArmyRover's Avatar
I have my wife program those things it's simpler for me that way
of them." unknown quote.
(offending Austrailians since 2008)
http://www.wheelinrovers.com/
91 Range Rover Classic
89 Jaguar XJ6
Old 01-05-2009, 10:20 PM   #5 (permalink)
The Zebra
LandyII's Avatar
Gallery: 17
David.
You're more than welcome!
It's doing great (she better be doing great!) LOL
Old 01-06-2009, 07:36 PM   #6 (permalink)
just know that when you think you have it programmed, don't just it the button to open the door, you have to hold the button for a few seconds. It really pissed me off at first because I was just tapping the homelink button like you would on a regular garage door opener. Remember, hold it down for a couple seconds when you want it to open and you are golden. I love the homelink... it has excellent range.
Kennay is offline   Reply With Quote
1999 Disco II AC Blower not working alwilson73 Discovery Series II 7 11-01-2009 07:29 PM
Thoughts on a 1999 Disco II for $4000, 166K mantio Discovery Series II 3 10-30-2008 06:45 PM
How many miles on your Disco II 1999? SafariDave Discovery Series II 12 10-13-2008 01:48 PM
Should I buy a Disco II 1999 with 167K SafariDave Discovery Series II 13 10-07-2008 08:32 AM
1999 Disco II for sale Brutus Land Rover Vehicles 1 04-18-2006 06:46 AM
