Old 12-06-2007, 11:24 AM   #1 (permalink)
Default Valve cover bolt head size?
Help - can anyone tell me what size the valve cover bolts are?
'99 Disco II - in the process of tearing it down to replace blown head gasket.
Stuck right now - trying to figure out the size of the bolts holding the valve covers - are those 12-point torx or what exactly? Looks to be around 8mm size. I thought I had a well-stocked tool box but nothing that works there. Will head down and get some smaller metric 12-sided sockets. Anyone have a better suggestion?
BTW, let me vent some frustration on the design of the engine. Whomever placed the ignition coils where they are, should be drawn and quartered - no less! Imagine the aggregated waste of time and general frustration - not to mention labor time - heaped on mechanics and paid for by owners just because of this idiotic design...
There are other issues too - such as numerous bolts are not accessible with straight extensions... oh, well, it's British engineering...
Thomas
krigsmakten is offline   Reply With Quote
Old 12-07-2007, 04:46 PM   #2 (permalink)
it is a 8mm, You need a 12 point socket and needs to be a 1/4 drive, you cant get a 3/8 inch drive in there
dgragu is offline   Reply With Quote
Old 12-07-2007, 09:07 PM   #3 (permalink)
Thanks -for the info - I eventually figured it out on my own this morning, and even though it's hard, you actually can get a 3/8 drive to work. You just need to lean into it. :-)
BTW, this is another example of idiotic British "engineering" - for this type of application, a standard M6 allen fastener would have served just fine, and caused a lot less trouble for all parties concerned.
URGENT--Stripped head bolt kkrover Range Rover Classic 6 01-19-2007 09:50 AM
Valve cover gasket stb616 Discovery Series II 3 08-03-2006 10:13 AM
Bell Houseing Bolt Size log burner Series Land Rovers 14 05-01-2006 04:22 AM
What is the bolt on the valve cover? Helopilot Discovery Series I 1 11-10-2004 10:21 AM
Valve Cover Gaskets? Helopilot Discovery Series I 6 11-09-2004 03:11 PM
