Ok...im totaly confused.
I had posted a question a few weeks ago and got some good info. I went back and followed the advice but the problem still presists. the problem is that as i drive down the road, I will loose the spedo (not the rev counter), when this happens the engine stumbles badly. I have noticed that when i make a right turn, and the weight shifts off the right wheels the spedo dies. when i straighten up the spedo comes to life. This also happens when i hit a bump on the right side. I had replaced the front hubs and sensors, I had checked the Alternator (ok), and I had removed the ECU and cleaned the connections (no signs of water damage) and I replaced the rear ABS sensor. My question is....Does the height sensor play into this problem? I noticed that it sends its signal to the same ECU. Would that have a bearing on the issue??? Do i have to possibly look at a replacement of the rear hub??? or could this be a faulty ECU??? I dont have a check engine light on. Since the wife drives the LR, I dont get alot of time behind the wheel, and therefore i cant get to it right away, Please any sugestions would be very much apreciated. thank you. ![]()
Feb 2001 disco II "ANOTHER DAY IN PARADISE" |
Stop throwing money at your truck, it not the height sensors for sure.
See if you can get Elemental to respond and tell you what sensor may be causing this. Mike |
| Thread Tools | |
| Display Modes | |
| Disco 2 tire decision - Very confused | Figman | Wheels and Tires | 3 | 03-20-2008 07:45 PM |
| I'm confused!... Magnacor Wires... help!! | johnnybob06 | Discovery Series II | 6 | 10-02-2007 03:00 PM |
| 02 RR HSE GPS confused | artcareer | Range Rover P38, Mk III and Range Rover Sport | 3 | 08-10-2007 05:16 PM |
| email from DAP iam confused help | bama | Discovery Series II | 6 | 12-18-2006 11:49 AM |
| LE or LSE? sooo confused! | errant | Discovery Series I | 4 | 10-02-2004 03:44 PM |
