Old 07-18-2007, 10:20 AM   #1 (permalink)
Default water leaking from headliner.. :S
Ok, so it's been raining alot over here, and I now have water leaking from the rear left passenger side of the headliner as well as right behind the A/C vent on the left hand side in the back.
Is it a hose that is loose?
Input would be great!
Thanks!
John-Robert
2003 Land Rover SE7
- Stock Hardon Karmon speakers
- Stock Navigation System
- Cold Weather Package
- SLS
- ACE
johnnybob06 is offline   Reply With Quote
Old 07-18-2007, 10:57 AM   #2 (permalink)
4x4 Adventure Gear
John C's Avatar
Was a common problem on Rangies and D1s, the drain hoses would get clogged and water would backflow into the headliner. Don't know if the DIIs have the same drainage system but if they do you want to blow air into the 4 drain hoses (2 in the front of the sunroof and 2 in the rear). Just open your sunroof and look for the drain holes along at each corner.
Hope this helps.
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 07-18-2007, 01:11 PM   #3 (permalink)
Sounds like a plan!
Where would the water drain so I can make sure the water is actually leaving the truck!
Thanks!
John-Robert
2003 Land Rover SE7
- SLS
- ACE
Old 07-19-2007, 04:56 AM   #4 (permalink)
ish
ish's Avatar
I believe they drain tubes run down the inside of the door jambs, under the "A" & "B" pillars
"Ish...I have in the past mistaken you for a perverted shit bag...now I realise that I am not shit bag enough. You truly are a king among men.I am not worthy with such imagination."
Series 3 Guy
2005 Range Rover HSE
2007 BMW X3 M Sport Pkg
1990 911 Cabrio triple black
2006 Mini Cooper S Checkmate - GONE
1987 Corvette - 18 yrs Gone,,, sniff sniff -
ish is offline   Reply With Quote
Old 07-19-2007, 08:49 AM   #5 (permalink)
Ok, well.. since I am not familiar with that, would it happen to be the front driver/passenger doors because I am getting water coming in through my seatbelt on both sides...
2003 Land Rover SE7
- SLS
- ACE
Old 07-19-2007, 11:59 AM   #6 (permalink)
4x4 Adventure Gear
John C's Avatar
One should drain down the A pillar (as mentioned by Ish) and the rear ones should drain by the C pillar (I guess that's what they call the pillar behind the rear dorrs.
Now, if the drains are clogged then water will stay in the sunroof rails and could leak anywhere, get the picture?
Here's a pic of the front drain on a Rangie:
John C
Old 07-19-2007, 12:01 PM   #7 (permalink)
4x4 Adventure Gear
John C's Avatar
and here is a pic of the C pillar (it's the black piece). The drain hose is inside that pillar and comes out by the wheel well:
John C
Old 07-19-2007, 12:02 PM   #8 (permalink)
4x4 Adventure Gear
John C's Avatar
What you should try to do is blow some air or use a coat hanger and see if you can unclog the drains.
Again, I'm not sure if the DII is the same as the Rangie but it's worth a try.
Good luck.
John C
Old 07-19-2007, 12:11 PM   #9 (permalink)
Steph's Avatar
had the same problem in the front when it would be pouring rain. what I found was happening, is that the drain tubes could not keep up with the incoming flow and would cause the water to come in through the dirt that had gattered on the rubber seal and on the inside edges of the sunroof. I came to that conclusion by simply taking a silicone spray and cleaning the rubber seal and the inside edges of the sunroof glass. Problem was solved.
Steph is offline   Reply With Quote
Old 07-19-2007, 02:03 PM   #10 (permalink)
got mud?
Jupiter Rover's Avatar
yeah me too. my sunroof drain liners were cracked.
DII
-- Pete
285/75 r16 Destination M/Ts
Jupiter Rover is online now   Reply With Quote
Old 07-20-2007, 09:39 PM   #11 (permalink)
check nipples on ac drain search forum for location...
papabeefis is offline   Reply With Quote
Old 07-21-2007, 06:23 PM   #12 (permalink)
Ok, thanks you all for the imput..
Now one thing I don't understand is, i my sunroofs are closed, how does water get into the drains??
That just makes no sense to me..
Could anyone explain?
Thank you!!!
John-Robert
2003 Land Rover SE7
- SLS
- ACE
Old 07-21-2007, 06:37 PM   #13 (permalink)
Steph's Avatar
When your sunroofs close, they close on the inner ring. Water gets on the suroundings of that inner ring where the evacuation tubes are located. If the tubes are clogged, the water stays there with nowhere to go until it can make its way into the cab through the dirt that built up on the rubber seal I told you about and the outside edges of the glass.
Old 07-22-2007, 06:15 PM   #14 (permalink)
oh ok! Thanks Steph!
Now, is it an easy job to blow out the dirt that is stuck? Where does the water drain from so I can see if it is actually draining...
With the silicone spray, did you spray it on the outside? and what does that do? I'm so sorry for asking stupid questions, I just want to make sure I do everything right!
Thank you so so so much!!
I really appreciate everyone's help!
John-Robert
2003 Land Rover SE7
- SLS
- ACE
Old 07-23-2007, 05:15 AM   #15 (permalink)
John's Avatar
I have a 04 D2 and for the life of me I cannot see any drain outlets whatsoever. There only appears to be the rubber seal.
John is offline   Reply With Quote
