I have a 2002 Disco. I am trying to get the fan clutch off of the water pump.
I am not having any luck. The shaft on the old pump is shot and all wobbly...
and impossible to hold still while I get at the big 36mm nut....
Is it possible to get the water pump off with the fan/clutch still attached??
I'm not sure there is the clearance to bring it out and up with the rad there....
I'm thinking of even removing the rad and trying that....though I am concerned about the access to the water pump bolts....while the fan is attached...
Help?
Help?
