Old 02-29-2008, 01:49 AM   #1 (permalink)
Default Weird brake issues, need help!!
Park the Disco for a while. Start to drive across parking lot, come to a stop. brakes squeal a little and Brake, TCS, ABS lights all come on. Turn off car, restart, all lights go off but ABS, start to drive abs light goes off. This same sequence has happened 5 times past 2 days. Seems only to happen when parked for more then a few hours. What the hell is going on here? 04 disco, 60K miles. Was thinking ABS sensor. ideas????
akwagon is offline   Reply With Quote
Old 02-29-2008, 07:57 AM   #2 (permalink)
'00 DII Member
auwesman's Avatar
Sounds like the vibration from your squeeling breaks is causing the 3 amigos. Take the pads off, but some "break squeel" and apply it to the back of your pads (comes in a spray can, or tube). 9 out of 10 times that will stop noisy breaks.
'00 DII
'07 Toyota Taco
War Eagle!
auwesman is offline   Reply With Quote
Old 02-29-2008, 09:24 AM   #3 (permalink)
"ditto"!!!
1990 Classic with brake and elec issues Help!! skippermccoy Range Rover Classic 6 11-07-2007 06:12 PM
wheel cylinder rebuilding theclay Series Land Rovers 23 05-21-2007 05:45 PM
Brake Pedal...weird vibrations when pushed boxer Range Rover Classic 1 12-29-2006 05:45 AM
Brake Squeal Discussion 01001010 Discovery Series I 4 11-08-2006 07:19 AM
Disco II Brake Issues... Chris Hyde Discovery Series II 1 07-24-2005 10:20 PM
