Old 06-23-2006, 04:52 PM   #1 (permalink)
Ontario Yours to Discover
Default Wet carpets, what the heck?????
Okay I know it's air conditioning season, so I will spare the whimpering. Both the passenger side and driver side carpets, under the floor mats are soaked. Hot and soaked, that is. I am thinking there is a drain hose for the air conditioing system that must be plugged and is dripping the water back into the truck.
Can someone tell me what is going on?!!?!?!?!?!?!?!?!!?
NiagaraRover is offline   Reply With Quote
Old 06-23-2006, 05:21 PM   #2 (permalink)
Easy problem to fix. You have 2 drain tubes that go thru thr floor board and drain down on both sides of the transmission. Get under the truck and look for the 2 drain nipples and clean them out with a piece of wire and you will be set.
Old 06-23-2006, 08:13 PM   #3 (permalink)
rmuller's Avatar
It's really fun when you're wearing sandals and make a turn.. you get a nice wet hot foot.. exactly what Mike said.. just open up the nipples.. you can stick a thin screwdriver or wire up there.. or just squeeze the rubber boot and it'll loosen up enough.. WARNING.. wear only an undershirt/tshirt as you will get a hot/wet/black armpit full of water.
Old 06-24-2006, 08:51 PM   #4 (permalink)
This sounds like an erotic adventure
I can't wait to get hot and wet, and give those nipples a squeeze!!!!!!
Old 06-24-2006, 09:03 PM   #5 (permalink)
Man oh man...this is reading more and more like a dairy commercial....lol...
6cuda6 is offline   Reply With Quote
Old 06-27-2006, 10:47 AM   #6 (permalink)
One more thing to look at if its not the drain tubes. There are two round plastic caps located where the windshield wipers are at the base of the windshield. When I bought my used disco one of the caps was missing and rain water would get in the exposed hole and end up in the passenger floor board. I couldnt figure it out for the longest time until I saw the hole. I covered it with tape and the floor was dry so I ordered a replacement cap and have never had a wet floorboard. Just my .02.
fvbrry is offline   Reply With Quote
Old 07-05-2006, 04:51 AM   #7 (permalink)
Well I cleared the drain tubes and the floors are now dry!!!!!!!!
Thanks for the tip!!!!!!!!
Old 07-05-2006, 06:49 AM   #8 (permalink)
So, make sure in the future that you give those nipples more attention.
