Old 01-29-2007, 07:58 PM   #1 (permalink)
'99 Disco II
wimp's Avatar
Default What Battery to get
The Battery in my '99 Disco II is almost dead. It is old; I tested it; it won't start the car if I have been plaing the radio for 20 minutes.
The question:
What battery should I put in?
Should I put in a normal heavy duty battery from WalMart?
Should I put in one of those Optima batteries?
What benefit do I have from putting in a "good" battery?
Someone please explain the difference and please recommend.
Thanks
wimp is offline   Reply With Quote
Old 01-29-2007, 08:29 PM   #2 (permalink)
'99 Disco II
wimp's Avatar
Default By the way
By the way:
I read a few previous posts regarding using dual batteries and using the larger marine Blue top Optima.
I am interested in simply putting a new battery in place of the old one and hooking up the the existing cables (maybe cleaning them up a bit).
Do any of the Optima batteries fit the stock tray?
Do the optimas last twice as long?
What is the difference between the Yellow and the red?
Also, which model of yellow or red is the replacement for the '99 Disco II?
Thanks again!
Old 01-29-2007, 08:41 PM   #3 (permalink)
rmuller's Avatar
Optimas have been hit or miss for a lot of people.. a lot of people have said that they stop holding charge.. I have 2 yellow tops in mine, I actually had to return one when I first got them b/c it was leaking gases... I've heard good things about Odysseys.
Old 01-29-2007, 08:58 PM   #4 (permalink)
Rocky Mountain High
Funrover's Avatar
OPTIMA.... I love mine... Both my parents had I have red tops in our rangies.. I also have a yellow top in my mercedes.
red - basic(for optima) gel cel, no corrosion like normal batteries, can take a beating, have great charge, will get you home if your alternator dies(personal experiance)
yellow - If you drain your battery down often this is great. They are designed to take large hits and recharge to full, that is why my diesel has one, it takes a bit to crank over in the cold.
blue - deep cycle/marine great if you have winches, tons of lights, etc etc.. unless you are extremely hard on the battery this may not be right for you!
They will all fit right in the Disco( I have friends w/ dI and dII that run them also) the P38 may take a little lift for the clamp to be secure, but that comes with the battery!!!!
Old 01-29-2007, 10:17 PM   #5 (permalink)
Otherwise known as STEVE
yellow and blue are the same- just different terminals. I'll never own another optima, ever... ever... ever...
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 01-29-2007, 10:36 PM   #6 (permalink)
Ian Matthews
p76rangie's Avatar
Optima are NOT GEL CELLS. They contain acid like any other battery. They tend to take longer to recharge compared to other batteries and mostly do not hold much power. That is, their amp hour rating is pretty low compared to most deep cycle batteries. They also hate the heat.
I have found Exide batteries good. Even though they do not sell my battery in the states, they do sell batteries with similar features to the Optimas, just a bit better than Optima.
http://www.exideworld.com/pdf/orbita...d_features.pdf
Old 01-30-2007, 04:59 AM   #7 (permalink)
we use interstate.
by the way you need 590 CCA AT LEAST.
Unless your in extreme cold climates then dont bother like alaska.
the factory battery rating will suit your needs fine.
even running some extra lights wont kill it.
Old 01-30-2007, 06:48 AM   #8 (permalink)
Polish and proud of it.
TsiArt's Avatar
I have a yellow top . i had to make a 2" high spacer to bring up the batt up .
My dad has the red top and couple times his would not start . He cused a lot and craked it over a lot for 45 min. It cranked over that 3.5l V6 with semi high compretion , and it did start ( i dono what was his problem ) .
My bro has a yello top in his Heep Cherokie and we go that used from my friend that he had it in his car for two years ( we go it for $30 ).
I have not had any problems with any of the optimas or any other batteries , eccept when they were 6 or 8 years old .
I'm a Proud owner of a vehicle that has a turning Radius of 747
Check out our Frappr!
Myspace ? It dose not mather who votes, only matters who counts the votes _ Krushchew
TsiArt is offline   Reply With Quote
Old 01-30-2007, 07:58 AM   #9 (permalink)
rmuller's Avatar
Here is the big consideration this week with Optimas:
http://discoweb.org/forums/showthread.php?t=31129
That is why Muddy Oval above said "I'll never own another optima, ever... ever... ever..." ... Keep in mind though, there is no conclusive proof yet that it was the optimas.
Old 01-30-2007, 08:00 AM   #10 (permalink)
rmuller's Avatar
Originally Posted by Rovin4life
we use interstate.
Stock battery with a winch, refrigerator, 6 offroad lights, on board air system, etc... ? Things add up, it's always nice to have a battery that can handle everything.
Old 01-30-2007, 09:27 AM   #11 (permalink)
Yeah- not conclusive except for the fire investigator and insurance investigator.
They are satisfied enough and I should be getting a check for the truck so I can replace it later this week.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 G4 Disco
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1973 SIII 88
Old 01-30-2007, 09:31 AM   #12 (permalink)
rmuller's Avatar
Ahh, so they did say it was definitely the battery then? Last I saw in the threads you were waiting for the official word.
Old 01-30-2007, 10:13 AM   #13 (permalink)
That's as official as it's gonna get, I think. The insurance company is satisfied, as is the Fire Dept. We went through all the wiring with a fine tooth comb looking for the cause and didn't find any faults in the wiring. The 'hot spot' of the fire is directly on the corner cell where the negative terminal is. There weren't any positive cables in that area.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 G4 Disco
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1973 SIII 88
Old 01-30-2007, 10:24 AM   #14 (permalink)
'99 Disco II
wimp's Avatar
Thanks for all the input.
Sounds like if you are dumb enough to put an battery in your vehicle that, at very best, lasts just as long as another "normal" battery, cost twice the amount, and might explode or give you trouble, then you are just asking for trouble.
Thanks for all the responses. I don't have a winch or any abnormal accessories (just some extra lighting). I live in the NOrtheast where it is seasonally cold (zero F sometimes). Sounds like a normal heavy duty batter from Napa would be fine.
Old 01-30-2007, 10:29 AM   #15 (permalink)
rmuller's Avatar
One of my friends picked up a battery from costcos, I believe it had 750CCA [same as a yellow top] for around $50 .. plus they have a 2 year no questions asked return warranty... he ended up bringing back a red top optima that was 1.5 years old that completely died and got full money back for it.
