Old 09-20-2006, 02:20 PM   #1 (permalink)
offroader
rivers edge's Avatar
Default What motor oil do I use?
Sorry I am asking so many questions, but I am a fresh owner of a 2000 D2 and I know hardly anything about how land rovers work! I will be posting quite a few questions for the next couple of weeks! Thanks
I have been told by a hand full of differnt people differnt answers, so I turn to the actual owners! What types of oil can I run without ruining the motor? Will it be possible to have it changed a local quick lube? And what octane gas can I run?
rivers edge is offline   Reply With Quote
Old 09-20-2006, 02:27 PM   #2 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Gas octane you should be using premium 91 or higher as specified in the manual. As far as oil, the dealer uses Castrol synthetic oil. Castrol is one of the best oils out there to fight sludge buildup, which Rover v8s' are well known for. Look around on Ebay motors for a RAVE cd. They have all the manuals on computer format and they sell for like 10 bucks, some place used to give em away free. Good tool to have.
Old 09-20-2006, 03:19 PM   #3 (permalink)
I agree with Badger go with Castrol, or spend a little more and buy their synthetic blend or pure synthetic.
Depending on how cold you get in the winter 10/30W or 10/40, in the summer go to 20/50W.
Might also see if you can find K&N 3001 oil filter larger then factory with a better quality of filter media.
Old 09-20-2006, 08:49 PM   #4 (permalink)
offroader
So this is what I am taking in from ya'lls info: I need to use a good quality synthetic oil(Castrol) and a heavy duty oil filter. I live in texas, so 10w/30 will probably be ok year round. and I filled it up with 91 octane on my way home!
Now, should I ever run a thing of fuel system treatment through it, maybe once a month or so? What about putting a quart of Lucas in it when I get the oil changed, would that do anything for it?
Thanks for any feedback!
Old 09-20-2006, 09:27 PM   #5 (permalink)
d2sti's Avatar
iv been using mobil 1, just cause i cant find german castrol synthetic around here
99' DII Niagra Gray SOLD
05' Subaru WRX STi Krystal Ghey Metallik
Revived 91' Isuzu Trooper Brownish-chipped-dented-rusty-white...275k and still kickin
d2sti is offline   Reply With Quote
Old 09-20-2006, 09:49 PM   #6 (permalink)
ภาษาไทย
llesra's Avatar
Gallery: 16
im using 5w-40 synthetic year round with a purolator pure one oil filter. i also put in a can of bg-44 in the gas at each oil change.
Arsell
My Car Domain Site
llesra is offline   Reply With Quote
Old 09-21-2006, 04:39 AM   #7 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Some sort of fuel injector cleaner is a must. Whether it be Lucas or better yet Redline complete fuel system cleaner...both great products.
Old 09-23-2006, 12:21 PM   #8 (permalink)
I used Valvoline High Mileage (I got 115K) 10W40 with genuine oil filter when I was back in Michigan. I still use it here in North Carolina. I also use Redline fuel system cleaner every now and then too.
Thanks,
Carlos
Carlos is offline   Reply With Quote
Old 09-23-2006, 01:27 PM   #9 (permalink)
Proud to be an Infidel
FlyWheel's Avatar
I alternate between Amsoil 20/50 and Amsoil 10/30 with the big K & N oil filter.
2001 Disco SE7
.......eventually they will run out of suicide bombers.....
FlyWheel is offline   Reply With Quote
Old 09-25-2006, 06:35 PM   #10 (permalink)
I've tried Amsoil, Mobil 1, Rotella and Castrol. I found Amsoil 20w-50 in warm/hot weather worked the best w/ K&N 3001 filter. I also use a can of sefoam in the crankcase and gas tank a week before the oil change.
d2offrover
Solihull Society
built2crawl is offline   Reply With Quote
Old 09-25-2006, 07:12 PM   #11 (permalink)
Rocky Mountain High
Funrover's Avatar
10w-30 Mobil 1 synthetic!!! and Lucas in the gas every 3000 miles and 91 octane
Old 09-25-2006, 07:57 PM   #12 (permalink)
RageRover's Avatar
I seem to have a problem finding 20W50 anything!
I wanted to use it in the truck after I got back from MRM, but couldn't find it.
I ended up going with regular Valvoline, 10W40. And since it is getting cooler out, I might as well stick with it.
But where can I find 20W50 Castrol Synthetic Blend, sounds like something I could use.
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 09-25-2006, 08:24 PM   #13 (permalink)
Rocky Mountain High
Funrover's Avatar
Auto Zone here sells it!
Old 09-26-2006, 06:35 AM   #14 (permalink)
Pat, if your auto parts store doesn't have it have them order you a case, it is worth it.
Old 09-26-2006, 03:38 PM   #15 (permalink)
mobil 1 ain't so bad!!!! full synthetic worked great for me 10w-30....but i do agree with mike on the castrol synthetic blends. And as far as the k&n long filter goes....not necessary for most, but i liked it for the large volume of oil it carries, those extra milliseconds the oil can cool down in that oil filter add up! Plus..you're driving a land rover, what's an extra 12 bucks for a good filter gonna hurt?
jordieb213 is offline   Reply With Quote
