There is froth in the oil and the exhaust is shooting black mess....
Please tell me this isn't what I think it is........ "
I stated that if it oveated that bad and he was replacing the head gasket that it would be a good idea to pressure test the block. In my case when the previous owner overheated the my Disco the result was a slipped liner as well as the head gasket. PT Schram also concured that from his decription of events the engine was likely toast. The other thread throws a lot more light into the why he thinks that.
That being said, was a pressure test of the block ever done? It was simply a suggestion to avoid doing the work twice.
Yes they did pressure test the block and it came out okay.
2003 Disco II
Custom front bumper, 2" Lift, Goodyear MTR Kevlar's Factory Rims painted Black and more miles then it should have!
You still guessing and worrying over if your engine is bad!!!
Not sure where you came up with dropped sleeves, you are your worst enemy when it comes to diagnoising and engine.
Quit guessing and pull the heads, for sure you have head gaskets and machine work with nothing besides your guessing, that you have dropped sleeves.
Ive never pulled heads before Mike.
Lift kits and the like, sure.
Clutches? Okay.
Never pulled heads though.
And from what im seeing these are a pain.
But I will go for it.
What are the odds I will not need to machine the heads?
2003 Disco II
Well that's real good news" Where do you stand with it now then? Is the shop saying what caused the over heat?
What caused the overheat was a throttle body hose that runs the coolant.
It failed and the truck lost all coolant.
And the girl who was driving it at the time continued on for like 30 minutes.
2003 Disco II
The thing is if this gets too expensive im just going to part the thing out.
Times are tough!
Yes times are tough for sure. They can get quite pricey to maintain but they are nice trucks. I would not keep mine if it was not just a third vehicle to have around. My titan has more power, better milage and 258K trouble free miles.
I am currently rebuilding the oil pump on mine and considered installing a new cam position sensor while I was in there but when I looked on ebay there ridiculous for a good new one. So back in goes the old one. There is no reason they should be that much just because it is a Rover.
Good luck with your repair.
You good luck with the repair too!
2003 Disco II
I would do the plugs and wires. Many on here like the 8mm STI wires and the Bosch 4 plugs and I agree. That is what I run and I am very happy with them. I see no reason to replace the coils unless they have failed.
2003 Disco II 113K Rebuilt
2006 Nissan Titan 258K
1966 VW Beetle Restored father son project
